Did Active Grille Shutter settings recently change?
cgskipper
Justin
Ada, MI
2024 Ford Bronco 4dr Badlands
I could have swore I saw a thread on this recently but I can't find it. Maybe it was on another site.
Did Ford make any recent changes to the Active Grille Shutter system? I noticed my shutters are at a 45 degree angle down, i.e. open/closed halfway when the vehicle is off. I thought they used to be left fully open when the vehicle was shut off.
'24 Badlands Lux with 2.7
Thanks!
Ducati1098
Thanks!
Doubt it. Unless you had a PCM update recently it couldn’t have changed.
RideClimbNJ
NJ
23Wildtrak
I noticed the same thing. Mine are at 45 degrees parked now. Figured it might be the freezing weather trying to keep engine warm. Wonder if it was an update.
Felix808
SRV CA
Mine are non existent thanks to Mr. Whipple 🤠
But as @Ducati1098 said, unless you had a PCM update, they shouldn't change.
cgskipper
cgskipper
Justin
Ada, MI
Revisiting my old thread. I think the shutter position at shutdown may be outside temp related. Now that it warmed up here a bit in Michigan, my shutters are back at horizontal upon shutdown.
