Deep Water Crossings / Fording
LHD
MN
Samurais, Corvairs, 914-6, TT, F350 SD
[/QUOTE]
Sorry, on this picture.
da_jokker
Jeep Wrangler JKUR
If it is designed for that depth from the factory why would the breathers need to be extended?
Wasn't there a debate as to what they meant. meaning just because Ford said it can go 30", it didn't mean you wouldn't have to flush out your diffs afterwards.
I guess my point is when a factory sets a water fording depth, are we certain the Ford is saying all the breather lines ALSO have been tweaked to match?
So no worries about shutters, low hanging alternators...etc.
Raptor911
Raptor911
Broadlands, VA
you don't need to relocate the breathers. on my Raptor, the rear diff breather is routed and sits right under the bed. In order to get above it you would have to submerge the entire back tire. Doing this means you are way past what is recommended.
Raptor911
Raptor911
Broadlands, VA
Invest in your $$ in a rear diff that can be easily drained and refilled without removing the diff cover. The oem diff cover does not have a drain so if you are the type who reg submerges your diff then replace the oem one. This is what I have on my Raptor.
Ford Bronco Deep Water Crossings / Fording 1621608505858
flip
Phil
IN
www.ruxerparts.com
Fords
I asked where the vents were for said components at the event on the 10th and have not heard back. This is a big deal to me.
Air inlet is right side under the hood as shown in the pic. They told us the inlet tube from the opening to the air filter box has a purposely built in drop and valve to allow water to drain before it turns into a hydro lock problem. I'm sure there are limitations to how much water it can take before it's unable to keep up but there is an additional layer built into the system.
Ford Bronco Deep Water Crossings / Fording 1621609010786
John Bronco_ I am here
North America
johnbronco.com
'66 Bronco, '08 JK
flip
Phil
IN
www.ruxerparts.com
Fords
Can't upload the video but the guides basically said you need to go fast enough to create a bow wave which creates a trough so not as much water get's into the engine bay area. Too fast and you are pushing water over the hood and creating a situation where water enters the air intake or fuse/smart junction box. I know this is nothing new for folks with experience but makes sense but it allows us to educate customers that have little or no experience, like myself. Last thing anyone wants is explain is why the engine is locked up after driving it like they do in the commercials.
MudHorse
Rod
Detroit, MI
66 Mustang Convertible, 2012 Audi Q7
That was kind of the point of my post. Just because they say it can do it, doesn't mean a prudent person with some knowledge wouldn't want to guarantee their investment is safe. I appreciate all the comments and suggestions. Ill be locating the breathers on mine and extending to set my own fording depth that I know is safe. I agree about the turbos and hadn't even considered that. But now I will. :)
North7
North Texas
SUV
Military trucks use turbo diesels and have tremendous fording capability. The turbo isn’t the constraint.
A civilian vehicle is not even close to the design equivalent of a military vehicle. Thousands of pages of design requirements from the government, tens of thousands of design hours to meet those requirements and then a mind numbing number of hours in torture tests to prove the design works.
Here are but a few test examples:
https://natc-ht.com/types-of-testing/
Techun
Pa
BD, 2.7, MIC, 4dr
A widely performed manuever in LR Series prior to water crossings is to remove the fan belt - fan beating the water and showering everything under the bonnet is disadvantageous……just saying.
Wire in a fan kill switch like military vehicles have for fording
Deleted member 3063
Guest
Trust but verify.
The Raptor is rated 30 some inches so I got under and checked the vents. I submerge the rear axle a dozen or more times a year at the boat launch. Previous F150s a similar amount. Never had a issue with water getting in the rear. Yep, I change my own fluids so I know. But there again I'm talking Fords, can't speak to off brands..
swooshdave
Portland, Oregon
Mustang
It would be neat if the Bronco had a water sensor that turned off the fan automatically when it sensed it was submerged.
martyb
Marty
Winneconne, WI
GMC Sierra Denali, VW Atlas
And the fan often shatters sending chunks of hard plastic through radiators, oil coolers, wires and hoses. ….
