Dealer
Hornet
Ford Explorer
My dealer said the the Big Bend must be ordered as Sasquatch according to the dealer guide and the system won't accept my order without it.
Anyone else trying to order a big bend without Sasquatch have this issue?
The post tracking our orders shows Big Bends ordered without Sasquatch - is that wrong?
Ford Bronco Dealer 0F2D743F-7F0A-4ACC-BB2B-8C6C33E63C9B
Bronco88
Ajay
Delta, B.C.
None
How does that make any sense? Mandatory Sasquatch would then put you into late availability? Something seems fishy, this package is only standard or "Mandatory" on the Wildtrak series.
DealerInsider
Tom
Horsham, PA
www.chapmannewcars.com
A stolen FE reservation
that is correct...WDBO wont let us unclick it
zrizik99
Zach
F150 2016
I guess it's when you select advanced 4x4 it's added as mandatory?
Lilj4425
Jacob
Greenville, SC
2021 Badlands Bronco
Your dealership is definitely wrong. Only FE and WT require Sasquatch. Could be a computer glitch that needs fixing by Ford.
Roger123
Roger
VA Beach, VA
The only way to get advanced 4x4 on a BB is to SAS it.
Hey19
JJ
Bethlehem
According to build and price, if selecting Advanced T-case, Squatch becomes required.
Used2jeep
Massachuvian
2007 Crown Vic P71
Answer: ROCKSTARS!!
Rob_Broncowski
MA
'22 OBX, Ducati Scrambler
Your dealer is an idiot. The note says Sasquatch is mandatory if you add the advanced 4x4 and 10 speed. If you want the advanced 4x4 without sasquatch you need to move up to a higher trim.
Toccoa
Isuzu Rodeo Sport
I agree. It needs the big tires. ?
Rocketeer Rick
Rick
Rochester, NY
2013 F150 STX 5.0L, 1999 Mustang Cobra
Agreed. The sheet clearly says that it is mandatory when ordered with 4A and the A/T. Don't order the 4A transfer case and the Sasquatch is not required.
Used2jeep
Massachuvian
2007 Crown Vic P71
Used2jeep
Massachuvian
2007 Crown Vic P71
Did you give them your B&P to work from?
Razorbak86
Northwest Arkansas
Ford Bronco, BMW R1150 GS
Are you trying to unselect:
(a) 765 (Sasquatch Package), or
(b) E5C/E5D (Advanced 4x4) #AND# 44T (10-speed auto)?
If the items in (b) are selected, (a) becomes mandatory.
