Dash Rattle 2022 Bronco
ecartaya
Miami, Fl
2022 Ford Bronco Black Daimond 2 dr
Hi all,
It’s minor but I have a rattle in the dash at around 2200-2600 RPM. It seems to come from under the dash near the windshield. Can’t seem to locate it. Many may not understand my OCD, but it bugs me. Thanks.
VelocityBronco
E
I get it...I have a rattle in the drivers side A-pillar. Coming from under the plastic trim? If I put pressure on it near the top it stops. I too am easily annoyed with small rattles...
I might pull the trim off to see if something fell inside while the top was off...
Mine is not RPM related, but happens when driving over bumps.
710-oil-614
Cal
Columbus, Ohio
2023 Maverick Tremor, 2010 Toyota Tacoma
Just wait for the top to start rattling or creaking and then you won't hear the dash rattle anymore.
threeonone
Canada
Jaguar
Does it sound like this?
VelocityBronco
E
Oh No! That is terrible, I feel bad for you if you are dealing with that daily. Mine is subtle, usually worse in the morning, which is strange, and only on bumps...
threeonone
Canada
Jaguar
Did you ever figure out what yours was?
webdz9r
Idaho
FE - Area 51
I believe I'm having the same issues, dealership as tried to locate it twice with no luck (typically they can't even reproduce it)
I recorded it, best if you listen with headphones, its faint sounding
BlueBoy
Martin
CA
1989 Bronco 351W
I have this same rattle on my 2021 First Edition. Did you figure out what it was?
Fordlvr55
Richard
Massachusetts
2022 Bronco 4 Door
My dash rattle comes from the passenger side area where the word bronco is. at low speeds it rattles, and if i put a little pressure with my hand the rattle stops
Ford Motor Company
Official Ford Account
Dearborn
Bronco, Bronco Sport
Y2KFirehawk
PA
2022 Bronco Wildtrak
Ford Bronco Dash Rattle 2022 Bronco 1784598512676-lo
Bringing some old threads to light in case I can help someone. I was chasing a passenger side dash rattle for months. Ended up being this "L" bracket on the passenger side inside the engine bay. It was loose.
