Dakota Lithium Battery Swap
21BRONCO
William
Los Angeles
21BRONCO
21BRONCO
William
Los Angeles
Saw that and didn’t need the dual battery setup because I’m not drawing a lot of power for accessories. Just needed a simple good battery that will last and won’t need to worry about it.
This thread may help. It's not a Dakota but is a Lithium Iron Phosphate battery:
https://www.bronco6g.com/forum/threads/trouble-charging-an-anti-gravity-battery.110860/
I adjusted my Battery SOC in Forscan to 100% - not sure even that was necessary and I may go back in and knock it back down - it's holding my Antigravity at around 13.4V resting (about 90% SOC on LiFePo). Pretty much just make sure you reset the BMS and allow the vehicle enough rest time to do the SOC calibration.
