Custom Interior Dome Lights, Flush Mount and Super Bright
smast
Austin, TX
2022 Wildtrak 4d Hardtop
Ordered IAG dome light kit for my 4-door hardtop Bronco, but really didn't like the way they stick out with the brackets. Looked far from stock. But their install video gave some clear instructions for running the wires, so decided to do a custom solution with flush mount LEDs. Picked the ones linked below because they have a low profile on the back side, mount flush, and are aluminum vs. plastic. Ran wires along the roll bar, then down the A-pillar similar to the IAG process. Trim pieces are easy to remove and pop back in, and these mount behind the airbags so no possible interference there. Tied into the door opening wire via vampire clip, and also ran a wire to one of the upfitter switches. Both work now. You do need to use a diode inline from the door open wire to where it connects to the upfitter switch so that the upfitter doesn't send current back through the dome light circuit. Overall, really happy with how bright it lights up the interior, how it automatically comes on with the door opening, and how it blends in when not in use. On/Off compare pics attached.
Ford Bronco Custom Interior Dome Lights, Flush Mount and Super Bright QBktTUSE0bCHjf2mdV99wO1Aw=w1058-h596-no?authuser=0 Ford Bronco Custom Interior Dome Lights, Flush Mount and Super Bright d8RHT-a9t2YFGzEqWYX4D1TdQ=w1058-h596-no?authuser=0
Ford Bronco Custom Interior Dome Lights, Flush Mount and Super Bright TnckWQwyTDXluOQGqsWoyNP4Q=w1058-h596-no?authuser=0
Ford Bronco Custom Interior Dome Lights, Flush Mount and Super Bright 4w_ufvtH3bHfWx9Qkm-W1AzTA=w1058-h596-no?authuser=0
Ford Bronco Custom Interior Dome Lights, Flush Mount and Super Bright tfiCx2DuXNsos7ecCou3WSUw=w1018-h1809-no?authuser=0 Ford Bronco Custom Interior Dome Lights, Flush Mount and Super Bright tBqFsxatZCWuYWSS16qHGgbhw=w1058-h596-no?authuser=0
https://www.amazon.com/dp/B01ADHUXGU?psc=1&ref=ppx_yo2ov_dt_b_product_details
Cornbred
Georgia
17 F-250/Edge, 14 F150,202? Bronco Base/Raptor
I like that it’s small, looks bright enough…nice work!
Gabby
Gabriella
Milwaukee
22' Bronco, 16 Tiger 800XCx, 96 Duc 900SS/Sp
Oooh! I'm adding these to my 82' Spider and my Bronco. Both suffer from a lack of lighting.
Big Woj
Channahon, IL
2024 Ford Bronco Badlands w/ Sasquatch pkg
QBktTUSE0bCHjf2mdV99wO1Aw=w1058-h596-no?authuser=0.jpg d8RHT-a9t2YFGzEqWYX4D1TdQ=w1058-h596-no?authuser=0.jpg
tfiCx2DuXNsos7ecCou3WSUw=w1018-h1809-no?authuser=0.jpg tBqFsxatZCWuYWSS16qHGgbhw=w1058-h596-no?authuser=0.jpg
These look amazing!
Ever thought of making a parts list? I'm really interested in doing this to mine.
TISU671
Frank
PNW
2022 Bronco Badlands Sasquatch
Can you share a simple wiring diagram?
smast
smast
Austin, TX
Big Woj
Channahon, IL
smast
smast
Austin, TX
Unfortunately I can't find the original installation instructions from V1 of the IAG light kit. Those had the details of the wire in the harness behind the kick panel that you need to tap to get the dome light signal. I need that in order to make a wiring diagram. Not sure where that leaves me in trying to help you replicate this. The new IAG kit looks like it has a more user friendly plug and play harness adapter
AdamF@IAG
Adam
Maryland
iagoffroad.com
'22 Bronco Raptor, '21 Bronco 2 and 4 door, '24 Ranger Raptor
We have obsolete product manuals on the website
Product Instructions
Ford Bronco Custom Interior Dome Lights, Flush Mount and Super Bright PdfImag
Ford Bronco Custom Interior Dome Lights, Flush Mount and Super Bright PdfImage2
Big Woj
Channahon, IL
I believe their V2 Kit they now include that box that plugs in to the rear dome light. Instead of tapping into to dome light wire by the fuse panel.
So couldn't I just use the v2 kit wire it up how they say to but instead of using their lights use the ones you got from amazon? I don't see why that wouldn't work.
smast
smast
Austin, TX
Yes I'm sure that would work and would make the wiring a lot simpler. Just costs more since you're buying that whole kit. Tapping into that door wire behind the kick panel was definitely the toughest part of the job
Blaylock1988
Colorado Springs
2021 Ford Bronco, 2004 Volkswagen R32
Do these gradually fade on and off when you open and close the door?
smast
smast
Austin, TX
Yes. Exactly the same as the stock interior dome lights
gdp
Arvada, CO
22 Badlands
I really like your idea and thanks for sharing. Just checking in now to see if you've had any issues or still happy with the installation. Also want to confirm it looks like you installed 3 lights on each side, is that correct? Thanks
smast
smast
Austin, TX
Still very happy with them. As much as the day I put them in. I also put two on the roll bar over the cargo area. Same lights and wired into the same circuit. That does a great job lighting up the rear cargo area when you open the door. Way better than the stock light on the side of the cargo area.
  • Like
Reactions: gdp
