Curious about constraints
Drvmustangs
Daniel
Sonora CA
1968 Mustang convertible / 2015 Subaru Forester
So just to start the dialog. As I continue my extended wait for my Badlands. my mind wanders to the constraints. Is anyone else curious about the semiconductor/ module shortage. How about the question to Ford. How is it you can be starting a all electric F150 and not build Broncos? Pretty damn sure it takes way more chips and modules to build a all electric F150 than a Bronco?
So Ford motor Company, is this political?
Notmattwong
Pilot Point, Texas
2021 Bronco Sport Outerbanks, 2026 Bronco Base
Yes, ford knows how you voted and they’re spiting you for it. How’d you know? It’s not like every other auto maker in the entire world is dealing with the same pandemic and supply chain issues……
F OR D
BD Green Machine
antenna shortage, need to uplink to aliens
jjack50
Jack
Temple, NH
2013 VW Jetta TDI, 2016 F350 4WD Crew Cab
Not all chips are the same nor are all types of chips under the same constraints. There are older less advanced chips that are proven by years of experience for some applications. Those are the chips on constraint. It’s not like Ford can’t get any of them, it’s that the rate of production of the modules that use them is lower than the demand for installation.
Newer, more high tech chips may have greater availability so their modules wouldn’t be as constrained.
equitasforall
Out of the country until late 2025
2021 Bronco Badlands
I was in the chip section at Food City in Morristown, TN about a half hour ago, and there was absolutely no shortage. I opted for the Chili Cheese Fritos and the Cheddar and Sour Cream Ruffles.
Plenty of chips to go around.
AZ_Liberty
2007 Expedition
When they say "chip" or "semiconcuctor" shortage. It's really just the media being lazy, and using that as a shorthand. It's not like it's an off the shelf processor. These things are highly proprietary and ordered a year to 18 months in advance.
These modern vehicles have multiple computer systems in them. These computers are (as I said) proprietary, and somewhat individualized, and generally only somewhat interchangeable.
At a minimum you have a Body Control Module (BCM) and an Engine Control Module (ECM). You may have a PCM (powertrain) which incorporates both an ECM and transmission control module. That's before you get into anything exotic like infotainment systems, or on-board navigation.
So, I am certain that these modules are identical on things like the Bronco Sport and Maverick (which are built in the same factory), but F-150 modules will be different, and Bronco ones will be different as well.
The Lightning is going to have completely different electronics architecture, so will use completely different control modules.
The real issue is that Ford (and to be fair, most other auto companies) anticipated a massive demand drop due to the pandemic. And to an extent that was true. We bought a 2020 F-150 in April of 2021 with over $7k of incentives because vehicles at that time were not moving. So now they have lots of orders, but they needed to order the chips in January of 2021. It's the perfect failure of JIT meets long-lead.
And it's not just Bronco. Bronco may be one of the least effected lines. At one point they had over 200,000 F-150 parked with no ECMs, and were considering schemes where they delivered non-working trucks to the dealers and then have the service departments install the ECM when they were available.
