Peitnahtan
Nathan
Los Angeles
N/A
Announcing the IAG Tailgate Air Compressor System for 2021+ Ford Bronco
The IAG Tailgate Air Compressor System for the 2021+ Ford Bronco is set to launch soon, bringing you new solution for tire inflation on the go. This onboard air compressor system is designed to make your off-roading adventures safer and more enjoyable, ensuring you can easily air up your tires after a day on the trails.
Air Up on the Trail
Deflating your tires for better traction on rough terrain is essential, but driving with low tire pressure on the highway can be dangerous and chew through tires. The IAG Tailgate Air Compressor System allows you to quickly and easily inflate your tires before heading home, ensuring a smooth, safe ride.
Space-Saving Design
The innovative design of the IAG Tailgate Air Compressor System integrates seamlessly into your Ford Bronco's tailgate. The air compressor mounts securely inside the tailgate and features a vented aluminum shield for optimal air intake and heat dissipation. The 1.5-gallon air tank is discreetly positioned under the spare tire mount, preserving your valuable cargo space and eliminating the need for bulky, external equipment.
Powerful Performance
Equipped with a VIAIR 400 air compressor, the IAG system is capable of inflating from 15 psi to 35 psi in just about 3 minutes per 37” tire. The VIAIR 400 is known for its durability and performance, trusted by off-road enthusiasts worldwide. With this robust setup, you can confidently air up your tires or use it for other pneumatic needs.
Versatility and Convenience
Beyond tire inflation, the IAG Tailgate Air Compressor System proves its versatility by handling a variety of tasks. Whether you're inflating air mattresses and water toys at the campsite, adjusting adaptive air suspension for heavy loads, or powering pneumatic tools for quick repairs, this system is your reliable companion on any adventure.
Easy DIY Installation
For those who enjoy working on their vehicles, installing the IAG Tailgate Air Compressor System is a straightforward process that can be completed in about 3 hours with basic hand tools. The system comes with a pre-terminated wiring harness, making the installation as simple as possible without the need for cutting or drilling.
Get ready to enhance your off-roading experience with the IAG Tailgate Air Compressor System for the 2021+ Ford Bronco. Stay tuned for its upcoming release and be prepared to tackle any terrain with confidence and convenience. Click the link below and select the "Notify me when available" button to receive an email when these go live!
Will you be selling the kit without the Viair compressor? Will this mount be compatible with another compressor (ARB)?
Badlands Traveler
Mojave Desert
Ford F150 XTL 4x4 2019. Bronco Badlands Sasquatch
Nice Option! The additional tank is a great add. More interior options would be nice.
But for the hose system....I love my PROFlate. Hands down really good quality. I have a write up I did about it.....https://www.bronco6g.com/forum/threads/pro-flate-4-wheel-tire-inflate-deflate-system.92017/
Hi, how were able to fit a motor driven compressor in a G6 Bronco? I would like to have one, but I didn’t think it was possible.
IAG Off-Road
IAG Off-Road
JJ
Westminster, MD
www.iagperformance.com
We are currently only planning to sell the kit with the compressor. However, we may change that if we get enough requests. For the time being, the mount only works with the Viair compressor.
Roofus
Swamp
M3/Bronco
I wish there was an air compressor kit that has an outlet next to each wheel, and the plumbing under the Bronco all worked out.
So you hook up all 4 wheels at the same time with little 2' hoses.
That's really not necessary. You can get a 4-tire kit from someone like Thor's Lightning and do all 4 tires at once up or down. Many of us use this with the AGS ARB dual compressor mount. https://www.bronco6g.com/forum/threads/ags-bronco-air-gate-kit-installed.65331/
https://thorslightningairsystems.co...apid-4-tire-air-system?variant=43299566387456
Ninjak
Miami
Question: How will this work if you do not have the OEM carrier? It looks as if the tank fits inside of it. If you do not have that as a carrier, will it work at all?
I have a Turn Off-Road Carrier mount.
IAG Off-Road
IAG Off-Road
JJ
Westminster, MD
You can still use the system without the tank in-line. Though we do highly recommend having it. With some creativity, I'm sure we could help work through a custom mounting solution of some kind if you have someone who can do some fabrication.
Yacktopus
Codey
SoCal
22 Base Bronco
will the tank have a problem fitting inside the spare tire carrier if you are already running a tailgate reinforcement?
