Cleaning Conundrum!
Eruption22
1999 Ford Mustang GT, 2020 Ford F-150
Hello Bronco Nation! I have a '22 Outer Banks in Eruption Green and love the hell out of it! However, it is a soft top and I live in Michigan. Our nasty winter will be here before you know it. My biggest issue in the first year of ownership, was keeping this rig clean all winter long. I take it to a Touchless wash, but it still doesn't ever look clean. I want it to look as if I just finished washing by hand, as in the picture attached. So, i figured, i'll have it ceramic coated, that will help right.....However, the more research I do, I find out that you should
Ford Bronco Cleaning Conundrum! Bronco
no take your ceramic coated vehicles through car washes??? Is this true, does the wash just ware the $1500 wax job away? What is the best way to keep the salt and grim off the vehicle when used for a daily driver? I'm looking for all options before winter arrives! Thank you for your suggestions.
Dubsesd
Andrew
CT
04 Ford F-150, 06 Roush Mustang
Hello, you should definitely get it ceramic coated. It will help you keep the truck clean. Just make sure you do your research on the shop that does it so it gets done correctly. A lot of places around me only are charging $500 because they are using spray wax with (ceramic) in it lol.
A good way to tell if it’s going to be done properly is ask them how long it takes, if they say anything less then 8 hours run haha. (Depending on what level of coating you do and how many coats you get applied)
Although hand wash is recommended you can go through the touchless washes. What breaks down coatings is abrasion. So car washes with brushes are a no go!
shoelessjoe
2013 Chevy Cruze
I had mine Ceramic Coated and hand washing it is super easy. Water beads right up and runs right off it.
JohnnyBronco
Pennsylania
X4
First note. This is Bronco6g not Btonco Nation. Those peeps might get upset with you tossing their copyrighted name around on competing forums.
Second if you want it to look hand washed then hand wash it. Yes my 21 OBX is dirty and needs a bath but in its 36,000 miles it has never seen the inside of a car wash.
Third there are polish (not wax) options you can do yourself for way less than a C-note which will last at least 6 months or more. (Astro-Shield is my go to)
Fourth. Did not have the Bronco coated but did have a 20 minute dealer applied option on our X4 and have never waxed it since.
Fifth. Makes a world of difference what soap and water you use to wash. Try Mutphy's Oil Soap and use soft water if you can. Hard water leaves spots.
MNBronc
Lutsen MN
2022 Bronco
Ford Bronco Cleaning Conundrum! 1692099351453
TCC
TC
Western NC
A few
I had a OBX soft top for a couple of years. Always hand washed just because of the fabric and plastic curtains. Every few washes I’d just use Maguire’s hybrid ceramic detailer. Quick and easy and left a great shine. MIchigan winters and road salt is the worst. Maybe just try to hose it off whenever it gets above freezing until you can give it a proper wash. Then again, it’s just a truck.
Scott R Nelson
Meridian, ID
I think maybe I made the right decision that I'm just going to let mine be dirty. I wash the mud and dust off of it regularly, but the black parts are never going to look new again, and I can live with that.
Ford Bronco Cleaning Conundrum! 2b7xOof
This is a more recent photo of me getting it "clean enough" to take to a car wash. ;)
Ford Bronco Cleaning Conundrum! 3h5JPxq
indio22
Chicagoland, USA
Man I bought that hybrid stuff on the advice of some people who swear by it - and it left the hood of my red car looking horrible. Like I had wiped grease all over the hood, especially noticeable at certain angles with the light reflecting.
Tried buffing it out with no luck. Finally had to use the damp towel method to cut it down. I'm hesitant to try it again.
Ended up instead going with old school carnauba wax. More work but apply, haze and wipe off goes as expected without the greasy streaking.
CTwaterfowler
Roger
norwalk ct
tahoe
Had my 21 ceramic coated, I researched around and use Adam's wash, Adam's ceramic sealer
I also got the nice soft towels to wash,bdry,. I apply the Adam's sealed after the vehicle has been buffed dry. I used another towel to apply the sealer and a Separate one to buff it dry.
The ceramic coating makes it a 1 and half hour job start to finsh.cyber orange reflects beautifully.
Adam's is definitely worth the investment.
Buy the gallon sized
MFP2241
WV
2 Door Antimatter Blue BaseSquatch
Wash it and wipe all the black plastic with VRP, it will look new again. It's not greasy.
Use it to clean all the rubber seals around the windows and removable top panels also, it will keep your Bronco sealed up, weather tight, and keep all those rubber gaskets from deteriorating.
Ford Bronco Cleaning Conundrum! Screenshot_20230815_095921_Firefox
Nice Base Squatch by the way... they are the best!
Ford Bronco Cleaning Conundrum! 20230508_124731
bkfit
BK
Spaceship
I live in Mi too just keep the salt off, under body blast from a touchless is my go to. Winter weekly washes...
Ford Bronco Cleaning Conundrum! IMG-6912
Scott R Nelson
Meridian, ID
The fender flares are already beat up enough to never look new again. They might look black, and shiny, but not new.
Blue Oval
1970 Bronco
As others have said not all ceramic coating are created equal. Talk to several detainers. The guy I used kept the Bronco for four days. First he clays it, then he does paint correction. Mine had some very light marks on the hood which I didn’t even notice. He said that could have happened at the dealership when they prepped it. Then he applies something that helps the ceramic coating adhere to the paint better. Then a coat of ceramic coating, wait an hour and a half. Then a second coat and wait 24 hours. Then a final coat of something else.
He said I can take it through a touchless car wash however it best to hand wash it. He recommened a product called Mothers CMX for wash soap. Don’t use a bucket when you wash it because the dirt will accumulate in the wash water and can scratch the paint. Apply the soap to the mitt and rinse the mitt out every once and a while.
He also said to bring it back in a year and he can apply a product that rejuvenates the ceramic coating.
helifino16
Ron
Mount Sinai, NY (Long Island)
I take mine through a Car Wash at least once a week and it's never been an issue. I have ceramic coated the windows and mirrors - after cleaning them thoroughly. Water sheds off these as expected, but I will still get spotting occasionally, but a quick wipe with a damp microfiber and I'm all good. I have to reapply about every couple of months - so Ceramic coating is not a once and done.
If you're looking into Ceramic coating the body, make sure that a thorough detailing, paint correction, clay bar, etc. are done as well. As with any vehicle, if you want it to look showroom clean, you have to keep it clean and covered.
