Chase Light suggestions?
TEAMSLO
NV
youtube.com
23' Bronco 2.7 4d Oxford White (sold) & '23 Jeep 392
I lead plenty of trail runs, at times I have used my blinkers as a workaround but the damn tick tock noises become extremely irritating. Anyone have suggestions preferably for Baja Design as this is what I run on my rigs up front but not a must.
There are options in the jeep world but not seeing anything for a chase light bar for the rear for the bronco. Couple of pods will have to do but I already have a current setup that may interfere with existing options.
I do have the option for them in the bumper but really wanted something much higher up.
@Turn Offroad & @Baja Designs
Ford Bronco Chase Light suggestions? 20240325_095530
swooshdave
Portland, Oregon
Mustang
I have the Diode Dynamics and they work great! I think you can get them so the red lights are also brake, and then I got yellow lens covers ( I leave the covers on all the time). They go on with reverse and then I have an up fitter switch to turn them on for trails.
Ford Bronco Chase Light suggestions? e46163cb-522e-479e-9e09-908cbc5f8ccd-jpeg-
Ford Bronco Chase Light suggestions? IMG_3307
4x4TruckLEDs.com
Adam
Lindenhurst, NY
www.4x4TruckLEDs.com
The Baja Designs kit connects to the upfitter only.
The Diode Dynamics kit connects to both the upfitter BUT also turns on automatically while in reverse.
With both kits they act as reverse lights but simply throw some yellow/amber covers on, and now you have chase lights.
We also sell both brands with our under-bumper mounted kit. With our kit, you can control them from the upfitter AND automatically in reverse. Add on some amber/yellow covers as I said to use them as chase lights
Baja Designs Reverse Kit for 2021+ Ford Bronco
https://www.4x4truckleds.com/baja-designs-reverse-kit-for-2021-ford-bronco/
(Shown with optional license plate bracket)
Ford Bronco Chase Light suggestions? 1711386693776-07
Diode Dynamics Stage Series Reverse Light Kit for 2021+ Ford Bronco
https://www.4x4truckleds.com/diode-dynamics-stage-series-reverse-light-kit-for-2021-ford-bronco/
Ford Bronco Chase Light suggestions? 1711386716022-50
2021+ Ford Bronco Reverse Light Kit w/Baja Designs Lights & KR Off-Road Brackets
https://www.4x4truckleds.com/2021-f...t-w-baja-designs-lights-kr-off-road-brackets/
Ford Bronco Chase Light suggestions? 1711386747209-s
2021+ Ford Bronco Reverse Light Kit w/Diode Dynamics Lights & KR Off-Road Brackets
https://www.4x4truckleds.com/2021-f...w-diode-dynamics-lights-kr-off-road-brackets/
Ford Bronco Chase Light suggestions? 1711386777894-iy
Diode Dynamics
John C.
St. Louis, Missouri
www.diodedynamics.com
Ford Bronco
This is awesome!
Some users will even swap white pods with a red backlight for a yellow lens instead of a snap-on cover.
The red backlight comes through the yellow lens with no visible color change.
Ford Bronco Chase Light suggestions? Yellow Pod Red Backlight
swooshdave
Portland, Oregon
Mustang
This is awesome!
The covers are somewhat cheaper and I can easily pop them off if I want to go back to white.
But good to know.
Diode Dynamics
John C.
St. Louis, Missouri
Ford Bronco
Ryslegit
SoCal
22 Bronco Badlands Sas
I believe Turn Offroad sells an accessory mount for the tailgate reinforcement which would allow you to put a chase light on. Might be worth looking into.
TEAMSLO
TEAMSLO
NV
youtube.com
@Turn Offroad anything? I don't see anything on the website
Shifts And Grins Fab
Ryan
Gilbert AZ
shiftsandgrinsfabrication.com
2023 Badlands, 2022 Bronco Wildtrak Sas
helifino16
Ron
Mount Sinai, NY (Long Island)
Someone recently suggested these. They're inexpensive and very bright. Easy to see through even the tinted window. May block the view out the back some, but very nice for a temporary (trail use only) solution. Offers a couple dozen light patterns.
Ford Bronco Chase Light suggestions? 1711459524834-55
Baja_bronco
Andrew
Hemet ca
2022 bronco wildtrak, 1996 bronco
Check out @Lobo Off-Road set up. Have them installed on my bronco and bad ass. It’s a duel light setup with lighted whip.
Bschurr
NY
Made my own from a 6” Rough Country Black Series bar, some L brackets, open lug nuts & threaded inserts
Ford Bronco Chase Light suggestions? IMG_6293
Gettyup
Rocky
So Cal
Bullitt Mustang, Expedition
I have Baja Design S2 lights with the Diode Dynamic reverse light bracket and hooked up to a SwitchPro so I can have the light strobe or be constantly on.
Ford Bronco Chase Light suggestions? IMG_6822
