Ceramic coat cameras?
CalvinT
Calvin
Phoenix, AZ
I'm having my Bronco ceramic coated. They're also doing the windshield, windows, grill and mirrors (other than glass). I have the High Package which includes 360 cameras.
My question, should I let them do the four cameras or should I tape them off?
Bschurr
NY
Absolutely!
tonytexchappy
Tony
Texas South Plains
08 Mini Cabrio, 22 Maverick
You’ll be glad you did
CalvinT
CalvinT
Calvin
Phoenix, AZ
Bschurr
NY
Absolutely to which?
Absolutely ceramic coat the cameras! It will make them easy to wash & help keep them clean as well.
DO THE RIMS/WHEELS TOO!!!
JAD67428
Steven
Just South of Boston,MA.
2024 Ford Bronco Big Bend with Sasquatch Package. 1994 Mustang G.T. 2023 Harley
Yes to the Cameras a yes to the Wheels !!!
CalvinT
CalvinT
Calvin
Phoenix, AZ
CalvinT
CalvinT
Calvin
Phoenix, AZ
Bschurr
NY
I'm getting the work done for $1300. They want another $250-300 to do the wheels.
$300 seems to be a bit expensive but consider that wheels tend to be one of the most challenging parts of a vehicle to clean since the brake dust and road grime get everywhere. A proper ceramic coating will allow you to simply hose (power wash) them clean with virtually no scrubbing and very little effort.
Assuming you wash your vehicle every other week, that’s 26 times a year. If the ceramic coating saves you 10 minutes of work for each wash that’s 260 minutes or over 4 hours/year. Ceramic coating can last up to 5 years so that’s over 20 hours over the lifetime of the coating. At an initial cost of $300, your 20 hours of time works out to be $15/hr which is less than minimum wage which makes the cost quite reasonable. YMMV
Mikey1287
22 Bronco, 72 Mach, 03 Mach, 69 Mach, 08 Harley
I use this about every 2 years and it works great. Takes a little time, but not hard at all.
Ford Bronco Ceramic coat cameras? 51WQwo-GglL._SL1500_
CalvinT
CalvinT
Calvin
Phoenix, AZ
From my research, Adam's seems to be one of the best.
