Center console storage issues
Sylvestermax
Tampa Florida
2023 Ford Bronco Wildtrack, 2015 F150 King Ranch
Who else has issues with the storage tray in the center console dropping down. What a poor design. Every time I need to get to the bottom section of the center console, that damn tray drops down when I try to pull it out, resulting in everything spilling to the bottom. Is anybody making one that has a handle or something that can be used to lift it out? I've looked and found several after market options. Does anyone have any recommendations?
Thanks
HeliPilot
Kenny
CT
2022 2.7L SAS
Try laying it into the grooves without locking it into the tracks. Should lift out easily then. Or, lock it into the grooves if you haven’t been by pushing down on it. Then you can reach past it without flipping it out.
Rydfree
Benny
Alabama
Thanks
This 2pc combo works well for me.
Amazon.com: TripleAliners Center Console Organizer Compatible with 2021-2024 Ford Bronco(no for Sport) Accessories 6th Gen Bronco 2/4-Door Center Console Storage Box ABS Material with Leather Trim(V2_Brown) : Automotive
Sylvestermax
Sylvestermax
Tampa Florida
Sylvestermax
Sylvestermax
Tampa Florida
Thanks for the info. I'll try that.
Sylvestermax
Sylvestermax
Tampa Florida
Robs
Rob
New hampshire
2023 Black Diamond
Thanks
lol. It plagues all of us!!! I put a cord through a hole in the tray and use that to pull the tray out when I need to get below. I also added some Velcro to the edges of the tray to keep it in place which has helped preventing spilling its contents
totaljustice
Kevin
Middle Sackvegas, NS
helifino16
Ron
Mount Sinai, NY (Long Island)
I saw a solution to your problem. I drilled 2 small holes in the top organizer and threaded a piece of Paracord to make a handle. Makes easy to pick up and guide back in place.
Canoehead26
Dryden, Ontario, Canada
2023 Ford Bronco
