Capable Bumper questions
Kimberley
Vermont
Yea, I wanna know if those aftermarket Gear America Tow Shackles will fit in place of OEM shackles?
Unfortunately not without some work and even then I am not sure how (if) the current shackles come off. That piece of the bumper around the shackle looks like it does come off but I do not see how the shackles would come off even if you got that piece off. Sorry I am not much more help, the long cold snap we have been having is not helping my research.
Tarheel_Wes
Wesley
FJ
Well, thanks….little bit of a bummer I wanted some white ones or to match mine with eruption green
I suppose I could try to pain them while still on the bumper if I really taped off/makes thoroughly around them, but a little nervous to try.
Snappy22
2013 Honda Pilot, 2022 Bronco BD
Agree.
my theory is they are essentially the tow brackets hidden underneath at the frame and just extended forward. So if the bumper is removed, those two steel shackle portions remain, and then they can be disconnected and removed from the frame connection.
If the shackle cannot be removed at this point, it’s likely we all just replace with something aftermarket that allows for greater flexibility or customization.
70&22bronco
Fallon
1970 Bronco
These pictures are so helpful! Thanks Kimberley!
I wonder if this is the bracket being offered by Ford now to mount the plates, or if this is something your dealer came up with. Everything else I had seen prior to this had the plates mounted higher (which I did NOT like..lol).
TankCommander
Nebraska
Jaguar F-Type R
This is the Ford front license plate bracket for the capable bumper. You will notice that it sits lower than the bracket for the modular bumper. Not too bad in my opinion but still requires drilling into the lower painted trim piece.
70&22bronco
Fallon
1970 Bronco
Thanks for that information!
I don’t like the thought of having to drill into a painted piece, but it is what it is, I guess. Lol. I think it looks pretty good there.
Kimberley
Vermont
I just want say that it is really nice of Kimberley to go out in the snow and take photos for internet strangers.
Thanks Kimberley!!!:love:
I wish I could have done more but this winter is going to be the death of me 🥶
FYI HBTFD just created one that drills into capable bumper. Not sure I want to try changing since I already have the holes but I do prefer the look a bit better
HBTFD
Newnan GA
F350
There you go!
Whatever that thing on the right side of your pic is, I don't have it on mine. The dealership said they had to put the plate on mine to inspect it due to state guidelines, I think they ignored/forgot my request to not mount it. You would most likely have to drill into it or get really creative for a plate on the bumper. Had not even thought about a second light next to the fog...
Here is a no drill alternative for the front license plate -
https://www.bronco6g.com/forum/thre...cket-no-drilling-required.37149/#post-1219750
Ford Bronco Capable Bumper questions 186E7321-719F-4BAF-977A-498083321BF8
Trilifter7
Ryan
southwest Ohio
2024 F-350 Tremor, 2022 Badlands 7MT
Does anyone know if the plastics ends behind the metal of the capable bumper come off? I thought I remember reading somewhere that the plastic piece on the ends closest to the tires was removable?
TankCommander
Nebraska
Jaguar F-Type R
Kimberley
Vermont
Kimberley
Vermont
HBTFD
Newnan GA
F350
It looked like it was bolted into the bumper....now I am really pissed at my dealership! Just got my license plates to put on so I will have to see how bad the holes are and if I can easily fill them.
Go to Lowes to the specialty fastener section. Find a plastic push pin that is the size of the drilled holes and buy 2. Get a bottle of touch up paint from a ford dealer ( or online) in the color of your bronco. Paint the pushpins with a few coats and insert.
