Capable bumper license plate bracket options?
mark2215
MA
2015 F350
The capable bumper is out there finally. Has anyone come up with a license plate bracket for this bumper?
HBTFD
Newnan GA
F350
4x4TruckLEDs.com
Adam
Lindenhurst, NY
www.4x4TruckLEDs.com
We've got you covered. Our bracket is made in the USA out of aluminum, powder coated and has a lifetime warranty. It requires no extension bits to install either. It's designed to use 2 of the factory mounting bolts on your truck and with your license plate installed, the mount is hidden so you don't see it sticking out. If you ever decide to go off-roading and want to remove it, you can do so easily as well
With the capable you just need to drill 2 holes to mount it (similar to what Ford does for your rear license plate bracket). Some folks use a nut on the back, others just use a self-tapping screw.
Use coupon code BRONCO6G and save 10%
https://www.4x4truckleds.com/kr-off-road-license-plate-bracket-for-2021-ford-bronco/
Ford Bronco Capable bumper license plate bracket options? 1644272953459
Ford Bronco Capable bumper license plate bracket options? 1644272957917
Ford Bronco Capable bumper license plate bracket options? 1644272963027
acetdeucy
daniel
Lincoln Corsair Lexus RX350
HBTFD
Newnan GA
F350
D-R0CK
Las Vegas, NV
2022 Bronco Black Diamond
The capable bumper bolt on front license plate design is complete. The first parts run for manufacturability and my meeting with the patent attorney is next week. I’lm planning on having brackets for sale within the next 2 weeks.
https://www.bronco6g.com/forum/thre...e-brackets-for-sale.23108/page-4#post-1203071
So excited for this! I was starting to resign myself to the factory bracket (which appears to sit lower on the capable bumper than it did on the modular bumper in the few pics I've seen, but still not ideal). Thanks for the work, can't wait to give you my money!
jeffryedvm
Richmond, VA
Broncos (96EB and 23WT), Mustangs (70, 88, 89)
I took @Downinthehazletwoods idea a step further. Found this bracket on the Amazon for just over $6. Comes with hardware to attach the plate, but I added some lock washers.
https://www.amazon.com/dp/B0113Y0UC4
Used the larger bolt (1/2" head) just a bit towards the center of the vehicle.
Ford Bronco Capable bumper license plate bracket options? 20230831_180905_mark
Ford Bronco Capable bumper license plate bracket options? 20230831_181647
Ford Bronco Capable bumper license plate bracket options? 20230831_181559
dagarbronc
Garth
Nebraska
2024 Bronco Heritage
Here’s my $5 Home Depot solution. There’s a bolt behind the bumper that I put a little bracket on, then just screwed it into the stock dealer plate holder.
Thanks for the idea - just finished installing the same on my truck - it turned out great and only a few dollars.
Ford Bronco Capable bumper license plate bracket options? IMG_3387
