can you put take off SAS suspension from a 4 door onto a 2 door??
miklos
nathan
pittsburgh pennsylvania
2022 bronco
i found a good deal on take off sas suspension from a 4 door and was wondering if i could put it on my 2 door?
Lcubed
l
UsA
VW golf r, 2023 ManBadSquatch
it'll fit but the spring rates won't be optimized for a 2 dr sas.
might be okay if armor/skid/etc have been added to your vehicle in the right places.
RagnarKon
Bryan
New England
Ford Bronco, Escape, Focus
@Lcubed is correct.
Ford uses different springs by the weight of the vehicle. So if you stick 4-door springs on a 2-door Bronco, your ride will likely be much stiffer.
It won’t be an issue, but it probably won’t be a super comfortable ride.
Bugkillah
Keith
North Augusta, SC
Jeep Wrangler, Nissan 370Z Nismo, Nissan Frontier
kodiakisland
Arkansas
12 Tacoma, 18 Indian, 23 GV70
RustysBronco
Matt "Rusty" R.
Jupiter, FL
www.instagram.com
2022 Ford Bronco Badlands Sasquatch
My two cents, but I'd wait to find a set for a 2 door. I'm sure you enjoy your new ride and you don't really want to hate yourself when it rides like trash after installing something you thought was going to be an upgrade, but wasn't.
Brutesquad
Las Vegas
Bronco Badlands
The spring rates will be different but not by much. I doubt there is an appreciable ride difference. If you plan on Bumpers, winch, skid plates, etc it would actually help manage the extra weight
Lcubed
l
UsA
the biggest difference will be if the donor is a 2.7 badlands automatic (max ford armor and heaviest engine) and the recipient is a 2.3 base 7mt
Brutesquad
Las Vegas
Bronco Badlands
Do you plan on adding Bumpers, winch, armor, rock rails, roof rack etc? If so it will balance out. The Badlands 4dr 2.7 (what I have) could not get a roof rack optioned. Either way, it wouldnt be like putting 1 ton springs on an F150. So to me it depend on what a deal I was getting on it. Aftermarket lifts are pricey
Beach_Bum
Ken
St. Augustine, FL
Quoting @Lcubed posts together for the OP.
To the OP, the Bilstein springs are targeted toward the original build spec. But that doesn't mean the set won't fit on another Bronco that is different. In many cases you would want a heavier spring to offset planned modifications to your Bronco. If you opt for a front winch/bumper and you have a 2-dr 2.3L, then you would benefit from a 4-dr 2.7L takeoffs to accommodate the additional expected weight. Same for the rear where some play the homeless-living-out-of-their-Bronco Overlanding Cosplay where they pack all their belongings for a weekend of camping, you would want the heavier springs.
