Can these be removed?
Maanameg
Melissa
Wisconsin
2022 Bronco (4 door)
Hi. Can these be removed? If so, what's under them and how can I remove them? Thanks in advance!!
Ford Bronco Can these be removed? DCA12019-DEF7-494A-BDD6-1E86076B1B44
Felix808
SRV CA
You can remove them, but then you will have a bunch of exposed bolt holes. 24 to be correct.
Maanameg
Maanameg
Melissa
Wisconsin
I'm getting them coated. Do you know what tool I would need to remove them? Sorry, not a tool person. Thanks.
BroncoSarge
Jeffrey
Fort Bragg, North Carolina
Yes. Many of us have had them color matched. Personally sent mine to a painter and drove without them for a week.
Ford Bronco Can these be removed? C2DDD821-DF3C-4773-B636-DDC1DC0E404D
BroncoSarge
Jeffrey
I used my cordless impact drill. Some were tough. They have loctite on them.
greatlakes
Grand Rapids
67 Buick Special
If you're removing them yourself, I highly recommend spraying them with a penetrating fluid like Liquid Wrench, waiting a few minutes for the fluid to do its thing, and then slowly removing them by hand. I do not recommend an impact wrench.
Maanameg
Maanameg
Melissa
Wisconsin
Maanameg
Maanameg
Melissa
Wisconsin
Thanks everyone!!
604Bronco
British Columbia
www.bronco6g.com
2024 Toyota Tundra TRD Pro
This is what it looks like when you remove them. Took this picture when I removed them to be powder coated black.
Ford Bronco Can these be removed? F4C8AC51-3C04-4462-9A3A-46A33541582D
PcDBronco
Paul
Corpus Christi
2021 Ford Bronco, 2015 F250 Superduty
Hand start the bolts when youre putting them back on dont use impact until they screw in a bit...had a tire shop cross thred 3 bolts and just shrugged and said the rim was faulty.
Wannabe Techie
Chicago
