Can I fit 35’s on a stock Badlands Non Sas?
Ron
Los Angeles, CA
2023 Bronco Badlands
Hello All,
Can I fit 35x12.50x17 BFG KO2’s on a 17x9’s+0 offset on my Badlands Non Sas with stock suspension?
Will I need to do a 1.5/2 inch lift?
I appreciate your feedback. Thanks!
MNBigfoot
MN
There's only a half inch difference between a non-sas Badlands and a Sas Bronco. Are you hitting the removable crash bars (Sas Broncos don't come with them).
BadlandsBroncoRV
Ron
Los Angeles, CA
Yes, I’ll be removing the crash bars.
BroncoAZ
Mitch
2021 2 Door Badlands manual, 2021 Tacoma TRD OR
I’m running 285/75R17 on +35mm methods, no rubbing with the crash bars still in place. I think you’d be fine with 315/70R17 or 35x11.5R17 on +30mm, but the little bit extra width of the 35x12.5R17 and the 0mm offset may rub.
MJ12
New Mexico
Dodge Charger 392
Should be able to. May have to delete crash bars.
TonkaTruck
Minnesota
Honda Pilot
Ford Bronco Can I fit 35’s on a stock Badlands Non Sas? IMG_4157
315/70r17 OEM Sasquatch fit well with crash bars removed. Seems like there is room for 35s.
SvgOne
Daniel
AR
2023 Bronco 4dr, 2021 Jeep JLUR Diesel
Just an FYI. I learned by digging through tire specs, while heading down a rabbit hole one day that the 31570R17 is actually wider than a 35x12.5R17. Anyway, not trying to be a know it all, just something I was surprised by. Nitto lists the true 35x12.5 at 12.52 width and the 315/70 at 12.72. Like I said, I get bored and go down rabbit holes.😆
Dimwit
Memphis, Tn
315/70R17 Nitto Ridge Grapplers on non-sas badlands. No lift. No rubbing etc.
BroncoDonco
VA
24 Badlands non Sas
Hello All,
What did you end up going with? I’m looking to put 35x12.5xr17 with +0 offset on a stock badlands non sas as well.
Thanks
BadlandsBroncoRV
Ron
Los Angeles, CA
Thanks
I went with 18x9’s +0 offset with 35s.
Removed crash bars and no rubbing at all.
HoosierDaddy
Indiana
Well, 35's will fit on a standard baseBase ... no lift, no crash bars, no rub on the street. Not sure I'd offroad too hard without a lift.
35 x 11.5 - 17 Toyo
Method 17x 8.5 , +35mm
Ford Bronco Can I fit 35’s on a stock Badlands Non Sas? 1701924510607
Ford Bronco Can I fit 35’s on a stock Badlands Non Sas? 1701924574804
