camber bolt and nut PN/source
65cobra
gary
sacramento
1970 Boss 302
I put the Zone offroad 2 inch kit on and In process one of the camber bolts was bad or overtorqued at the factory and kind of stripped itself off, and took a ton of torque to tighten up. I want to replace it when I get it aligned. Does someone know a PN or source to get another one?
Mikec0078
Nebraska
2022 Ford Bronco
I had the same issue, called the parts dept and they said they are backordered and have no est date. I had some bolts from a precious lift enough to get me to the alignment shop, they said those were fine. I'm still waiting on oem cam bolts though.
65cobra
gary
sacramento
1970 Boss 302
I ordered some online, they made me order 4.... with nuts $50 Ill send you one if they show up lol
Broncola
Hawaii
Element, ‘75 Bronco widow
Where’d you order from and what’s the part number. Been wanting to level mine using this method, but worried mine will strip too.
65cobra
gary
sacramento
1970 Boss 302
Some online site that said they had it but they do not.....
rtaylor
R
ID
19Raptor, 22Bronco
Same issue with one of mine. The nuts are easy to get, but the bolt/washer has been backordered. The stripped one is working OK for now (tighten/loosen over and over in vise to somewhat restore bolt to working condition).
Just mark the cam position after alignment, then you can replace the bolt later.
W720555-S439​
Bolt And Washer Assembly - Hex.Head​
$8.78​
1​
$8.78​
W720216-S442​
2019 2020 Ford Ranger - Lower Control Arm Nut​
$2.28​
1​
$2.28​
wyobronco
Clint
Wyoming
'21 Bronco Black Diamond 2 DR
Im dealing with the SAME DAMN THING. unreal.
jwvice
Jeremy
Hoover, AL
Ford Platinum F150
Yep, me too. Went to level mine and same issue, same location. Bolt is backordered. My dealer is trying to escalate. I spent an hour on the phone with @fordmotorcompany and a customer service agent who did not care the least bit about my issue. Very disappointing..
65cobra
gary
sacramento
1970 Boss 302
did anyone check if the Ranger bolt is the same so we can pull one from the junkyard?
I asked my local dealer, they said no but, well I don't trust them...
rtaylor
R
ID
19Raptor, 22Bronco
The bolts are finally shipping. My guess is that Fairway has some spares in stock now, since they have to order 4 at a time and I only bought 1.
Ford Bronco camber bolt and nut PN/source 1651160914503
65cobra
gary
sacramento
1970 Boss 302
Who thanks r Taylor I got one from fairway. I’ll probably pay double for the set of 4 nuts I ordered from the local dealer
Ford Bronco camber bolt and nut PN/source C713020F-19C3-436A-9887-9E08A1AA8882
NateTTU
Nate
Fort Worth, TX
2025 Bronco
W720555-S439​
$8.78​
1​
$8.78​
W720216-S442​
$2.28​
1​
$2.28​
Does anyone know what the part number is for the washer under the nut?
•edit•
I was thinking the bolt side and forgot about the nut side - so disregard.
NateTTU
Nate
Fort Worth, TX
2025 Bronco
I think it's this, just found it browsing the ford part website.
W720186S439
Dusty
Mentone, CA
70, 71 & '21 Broncos
I bought a full set of 4 each (bolt and nut) from RFD Auto Parts. The threads on mine were getting a bit worn out anyhow, and I wanted to get new ones to install the Cam Lockout Plates from Zone Off-Road with fresh threads. I put the lockout plates on the new bolts, and kept the old bolts intact. Took the Bronco to the alignment shop with the old bolts to get it aligned, then brought it home and swapped in the new ones with the lockout plates.
Part NumberPart NamePriceQuantityTotal
W720555-S439Lower Control Arm Adjust Bolt$10.904$43.60
W720216-S442Lower Control Arm Nut$4.084$16.32
Subtotal: $59.92​
Estimated Shipping to 92359 via Standard Shipping: $14.47​
Tax: $5.77​
Total: $80.16​
