CAI Popping after install
Willub
Billy
Massachusetts
A vent to atmosphere bov should eliminate the sound in hearing
Nothing is going to eliminate the sound you are hearing, other than putting the stock intake back on. A VTA valve may make it worse, as you’re getting rid of metered air and temporarily richening the mixture. By how much? Probably not a lot, but it’s not beneficial. A VTA valve may be loud enough to mask the popping you’re hearing if that’s what you’re after!
bbacon05
Brent
Baltimore
2003 Honda Element
He's right, stock intake will be the only way to eliminate the sound. Older turbo cars you could always hear the blow-off valve, but on newer cars they create the intake in a manner to quite all the turbo noises down.
Also metered air issue you are referring to doesn't apply to the Bronco because they use a MAP sensor instead of a MAF sensor so the air isn't measured until the intake manifold anyways so there would be no un-metered air.
Willub
Billy
Massachusetts
Good point, I’m used to the old MAF systems
ericwmedic
SE Michigan
17 Focus RS NB
I have the K&N setup with the dry filter on my 2.3L. It does the same popping noise.
What's really gonna drive you nuts is being on the expressway with the cruise control set, and you'll hear the popping noise as you go up/down hills.
It's just what others have said; the Bypass Valve controlling boost. The 2.3L EcoBoost has a unique torque-demand strategy (program) that uses a combination of Wastegate Duty Cycle, Bypass Valve Duty Cycle, Spark Timing, and Fuel Trim to control power. It's almost irrespective of throttle position.
AzureBandit
Maryland
2023 Black Diamond 2013 Mustang GT
I couldn’t stand it…ordered and installed the turbo smart dual valve bov the popping noise is gone!
DesertMike680
Las Vegas
Same! I replaced the stock BPV with the Turbosmart and the popping noise is gone. Going to install the Injen intake tomorrow morning, which is replacing the Roush intake.
DesertMike680
Las Vegas
Hey y’all, looking for some insight. I just installed an Injen CAI on my 2.3L 2023 BD. After install I noticed what sounds like an intake backfire. Has anyone else had this issue?
I’ve already went back and check all my hose connections and clamps everything is tight.
Do I need to get a tune to fix the issue? Or did I miss something?
Thanks in advance!
Was the install a big pain in the butt? Im going to tackle it tomorrow morning.
DesertMike680
Las Vegas
AzureBandit
Maryland
I should have specified - I have the 2.3 manual.
All good just wanted to make sure the 2.3 like I have. It is not bad at all took about 35-45 minutes just to make sure I had the clamps and hoses on properly and tightened well! From what I hear the 2.7 is pretty time consuming. The tool Injen gives you for the one breather hose is actually great! Shouldn’t take you that long at all!
DesertMike680
Las Vegas
Ok awesome! Did you have to pull the skid plate off as the directions mention? With the being said, the directions make it seem like it's more difficult than it seems.
AzureBandit
Maryland
I opted not to take it off at first…. They tell you
To take it off to be able to remove the lower part of the intercooler piping. I did it from the top… I did end up taking it off in the end to make sure I had the intercooler pipe back together properly.
DesertMike680
Las Vegas
Ok gotcha. So taking it off and getting to the intercooler wasnt that bad?
DesertMike680
Las Vegas
No not at all. We have a lot of room with the 2.3l near the radiator and intercooler!
Ok that's awesome. Last question - noticable performance improvement over stock? Sound and power?
