Cab Access Grommet - Under Glow
Chapito
Laredo, TX
2023 Bronco Wildtrak
Hello I’m looking to install an Opt-7 underglow kit and wanted to see if anyone has used an existing grommet on the floor board to access the cab nearest to the driver. I’m prob going to go with and add a fuse on the interior fuse panel on fuse #2. Any help would be appreciated.
Chapito
Laredo, TX
This is where I ran my amp wire. 2dr 2.7 auto.
Thank you I was looking for a possible grommet on the driver floor. I’m about to go check it’s just 100 degrees in Texas and the concrete is not my best friend right now lol.
Shane78
Shane
St. Louis
2D
Save yourself some busted knuckles. Pop the grommet out, poke a hole in the nipple with flathead screwdriver or cut X with a box knife razor big enough to get wire through then reinstall. Absolute pain trying to cut the hole while the grommet is in place.
Chapito
Laredo, TX
I ended up using the smaller grommet right above the main one on the firewall. Popped it out and cut it.
Ford Bronco Cab Access Grommet - Under Glow IMG_6092
