Bumper Removal Help (non modular)
Hblhtx
Hunter
Houston
My bronco came with the factory bumper (not the heavy duty modular) and I am planning to replace it with a new DV8 bumper. It seems like the removal of the factory bumper may be a little trickier than the modular one. Any guides out there or help? Thanks in advance.
Rednek
Jimmy
Northern Alberta
Removal
NOTE:
Removal steps in this procedure may contain installation details.
  1. With the vehicle in NEUTRAL, position it on a hoist.
    Refer to: Jacking and Lifting (100-02 Jacking and Lifting, Description and Operation).
Vehicles With: Front Fog Lamps/Front Parking Aid
  1. Disconnect the front bumper harness electrical connector.
Ford Bronco Bumper Removal Help (non modular) video
Ford Bronco Bumper Removal Help (non modular) Hel
All vehicles
  1. If equipped.
    Remove the screws and the front license plate bracket.
Vehicles With: Front Parking Aid
    1. Release the clips and remove the front bumper trim panel.
      Use the General Equipment: Interior Trim Remover
    1. Disconnect the front parking aid sensor electrical connectors.
All vehicles
  1. NOTE: This step requires the aid of another technician.
    Remove the bolts and the front bumper.
    Torque: 81 lb.ft (110 Nm)
Installation
All vehicles
  1. To install, reverse the removal procedure.
  1. Check the alignment of the front parking aid sensors.
    Refer to: Azimuth System Check (413-13A Parking Aid - Vehicles With: Rear Parking Aid, General Procedures).
    Refer to: Elevation System Check (413-13A Parking Aid - Vehicles With: Rear Parking Aid, General Procedures).
  1. If any sensor fails the check, diagnose the sensor fault.
    Refer to: Parking Aid (413-13A Parking Aid - Vehicles With: Rear Parking Aid, Diagnosis and Testing).
© Copyright 2022, Ford Motor Company.
TBroncski
Tybor
FJ Cruiser
Does the DV8 bumper work with the factory skid plate or no? Kinda been eyeing that route myself.
evgenyvasenev
Evgeny
Gig Harbor, WA
www.instagram.com
Ford Bronco Badlands
Removal
NOTE:
All vehicles
  1. If equipped.
All vehicles
Installation
All vehicles
  2. If any sensor fails the check, diagnose the sensor fault.
Thanks. Is it the same for the steel one?
Hblhtx
Hunter
Houston
Not sure. Hoping it does and I don’t find out the hard way that it doesn’t.
Headsong
Uh, if it's the not so capable bumper, you pop the plastic plates, remove 6 bolts and unplug the fogs. Ez.
