Looking for help with part numbers- Parking Sensor Retainers for Modular Bumper
LoneRider
Wayne
Marysville, WA.
2022 Bronco
I bought a used, take-off Modular bumper for my OBX to replace the plastic bumper.
Was kind of surprised to find that the little plastic retainers for the parking sensors are different depending on which bumper you have.
Called the local Ford dealer and explained it all, and they ordered up the ones for the Mod bumper - or so I thought.
They are NOT the right ones and they are also different from the OBX bumper ones (plastic base bumper with fog lights if that matters)
Can anyone advise which are the correct part numbers?
TIA for any info
Brisco2
NJ
2012 F350 XLT, 2018 Ford E350
I did the exact same thing,
Part: M2DZ 15A862M* (* = A, B, C, D) Each of the four are marked to where they go. "FIR" means front inside right etc. The FOR, FIL lettering goes to the ground with the Ford symbol going up.
Reach out with any questions, maybe I could save some aggravation for you.
I will make a post with photos one of these days
LoneRider
LoneRider
Wayne
Marysville, WA.
2022 Bronco
Thanks, I was able to talk to dealer parts guy. He figured out mistake was he selected “metal” bumper and ordered the parts with CA-CD suffix.
Evidently Ford parts call the Mod bumper something else. He pulled a VIN of a Bronco with mod bumper I ordered that way.
Hopefully will have them Friday. On the bright side, I’m getting pretty good at removing, disassembling, assembling, and installing bumpers!;)
Ranbronc
Pa
Early Bronco
my Rock Hard bumper came with Mopar ( jeep) retainers, no idea the part numbers
Drew5150
Drew
1975 International Scout 2
So the only difference is the retainers? the sensors are all the same on plastic and modular bumper?
Brisco2
NJ
I believe so. I reused the sensors and the wiring harness from the standard bumper in the mod bumper and everything works as it should.
the314boss
St. Louis
2023 Bronco Raptor
i have a fairly basic question i hope you can answer: i need to replace the bumper on my BRaptor this weekend and one of the sensor retainers is damaged. can i replace the retainer clip and reconnect the sensor with the bumper mounted, or do i need to remove the bumper to do so?
said a different way: can i do the larger project of swapping bumper for new unit and replace the retainer later, or do i need to wait?
thanks for your help!
Brisco2
NJ
I'm going to suggest wait.
While you can easily get the old retainer out from the front and the new one in. Clicking the sensor in the retainer would be near impossible on at least two of them, maybe all four. There is a reinforcement behind the mod bumper which blocks the back of the retainer.
It was about a year ago, but I am pretty certain the outer two are blocked for sure. Check with a mirror/flashlight and you will see what I mean.
the314boss
St. Louis
2023 Bronco Raptor
roger that, thank you!
