Built a rear deck for 2D Bronco.
Jubear
Fraser, Michigan
Subaru Crosstrek
Well, I needed a rear deck for my 2D Bronco and took a weekend to build one. That being said, I will still be ordering the Goose Gear deck over the winter. But this will hold me over until then. All made with 3/4 in plywood and bed liner paint. The hardest part is getting the correct length for the bolts and the hole placement for them. Enjoy the picks!
Ford Bronco Built a rear deck for 2D Bronco. IMG-3595
Ford Bronco Built a rear deck for 2D Bronco. IMG-3598
Ford Bronco Built a rear deck for 2D Bronco. IMG-3601
Ford Bronco Built a rear deck for 2D Bronco. IMG-3604
Ford Bronco Built a rear deck for 2D Bronco. IMG-3606
Ford Bronco Built a rear deck for 2D Bronco. IMG-3605
Murph914
Franklin, MA
2008 F-350 reg cab srw v10 manual
The goose gear looks so good, but their price just seems a little too high.
Jubear
Jubear
Fraser, Michigan
Subaru Crosstrek
Cost in bolts alone was about $100. The rest was not bad, as I had wood and liner on hand. But I do like the Goose Gear stuff. I like the recessed bolts and other options to add later. Yea a little expensive but probably worth it in the end.
AMCheese
CA
Looks great! Dibs on this one when you get the Goose gear. HAHA, just kidding, unless you live nearby.
Jubear
Jubear
Fraser, Michigan
Subaru Crosstrek
Sorry, Just outside of Detroit. Little bit of a Drive to drop it off. LOL
TheShark
I have the Goose Gear which I really like but you did a great job. Get yourself something like a rubber mat and cut it to shape and that may help with the bolts not being recessed.
IDyeti
SPAM
Boise, Idaho
21 Bronco BD
So a trick to getting the hole locations to line for projects like this is to put the bolts in the holes a few threads. Then line up your wood and smack each location with a rubber mallet. The bolt should leave a good impression on pine plywood, remove wood, then drill the holes from the back side.
Did that one my DYI camp kitchen box and everything lined up perfectly.
Jubear
Jubear
Fraser, Michigan
Subaru Crosstrek
Did that with the first level boards. but second level was a little more tricky. But got them all lined up after checking many times. Happy with the end product for now.
mcinfantry
Lee
Louisiana
Badlands 2 door
mcinfantry
Lee
Louisiana
Badlands 2 door
My plan is something similar with marine board (plastic)
Jubear
Jubear
Fraser, Michigan
Subaru Crosstrek
mcinfantry
Lee
Louisiana
Badlands 2 door
Thanks, the beast is still a work in progress.
I’ve built a few!
cummins 4bt
Nv4500
A/c
Disc brakes
Power steering hydraulic assist too
Detroit rear 14 bolt
60 front electrac
38” USMC LAV tires on Hutchinson beadlocks
stock height!
goatman2
Richard
Bakersfield
gandgautorepair.com
F450, Jeep XJ, Porsche 911, 2dr Badlands
Jubear
Jubear
Fraser, Michigan
Subaru Crosstrek
mcinfantry
Lee
Louisiana
Badlands 2 door
I miss that vehicle more than anything I’ve ever built or owned
