Built a rear deck for 2D Bronco.
Jdyount
Kansas
2021 Badlands
Cost in bolts alone was about $100. The rest was not bad, as I had wood and liner on hand. But I do like the Goose Gear stuff. I like the recessed bolts and other options to add later. Yea a little expensive but probably worth it in the end.
Seems like you're a pretty accomplished wood worker, why didn't you just use countersunk bolts? With 1 extra step you get a much cleaner install. Other than that, your stuff looks as good as the Goose Gear stuff (minus some of the extra accessories).
Jdyount
Kansas
2021 Badlands
broadicustomworks
Hanging Rock, North Carolina
I'm with @Jdyount on this.
Maybe I'm not seeing something GG brings to the table for the cost, but your work here looks great to me.
Functional, protected with the liner, good Fit and finish work, and if you countersunk those bolts, personally it would work for quite a long time for me. If it were my rig.
I think you aren't giving yourself or your project here enough credit. I think it looks pretty killer!
But to each their own.
If I were a 2Dr owner I'd be more than happy to take this one when you switched to the GG.
Jubear
Jubear
Fraser, Michigan
Subaru Crosstrek
Thank you
Roger123
Roger
VA Beach, VA
After seeing what you have there you will be very disappointed with spending a grand plus on GooseGear. I'm sure their stuff is fine but no way is it better than what you've done.
You can also pull the seatbelts from the lower mounting points and Ty-Wrap them out of the way up by the roll bar. That's how I did mine.
Great Job.
