Budget minded ditch lights
Mean Red GT
Kevin
TN
2022 4 Door Badlands/2016 Mustang GT PP
darinhouston
Darin
U.S.
Bronco, Jeep Wrangler, Bronco Sport, Pallisade
Set of 2 from Tractor Supply =$85. Good wiring harness, weatherproof connectors, light output is just fine and dandy.
I have two of them on my cowl. They look all cool and blacked out when not on, and have a low-light amber ambient function if you wire it to a separate switch than the white output.
TravellerX 4 in. Blackout Pod Lights with Amber Function, 2-pack, TB110-05146 at Tractor Supply Co.
Aux switches? Did you have to run a separate wire for the amber?
broadicustomworks
Hanging Rock, North Carolina
I’ve since replaced them, but with another set that also uses a backlight.
Yes, I ran the backlight to one of the low amp aux switches and the brighter spot to another.
It ties up two switches but at present I still don’t have all of them used and dedicated.
If I ever see I need to I’ll run them to a small hidden switch somewhere else.
darinhouston
Darin
U.S.
Was it hard to route a new wire along the path of the pre-routed one?
