Budget minded ditch lights
gtx_bronc
GTX
Are you guys using a mounting bracket or just direct mount? Haven't got my Bronco yet so not sure how that really works. I was looking at these. Not too bad at $75 but then $30 shipping
https://www.bodyguardbumpers.com/bronco-cowl-light-mounts
i used the bracket that came with the DD's but am ordering the ones you listed because of the offset. It will move them outboard away from the antenna. For now i just removed the antenna and put in an amazon plug. Amazon.com: KSaAuto Antenna Delete Cap Car Washing Antenna Protection Cap Kits Compatible with Ford F150 2009-2021 Car Wash Proof Antenna Delete Plug Parts and Accessories Short and Compact Size : Electronics
4x4TruckLEDs.com
Adam
Lindenhurst, NY
www.4x4TruckLEDs.com
Looking to install some ditch lights, but have no desire to spend thousands or even hundreds of dollars on them. As they will be more for looks than used. I've had my far share of Amazon lights, some good some bad. I am looking for recommendations for some decent if there is such a thing Amazon led lights. I know I can't be the only person who is like minded. Thanks
Ya know for $210 you can get some Diode Dynamics right here: https://www.4x4truckleds.com/diode-dynamics-stage-series-ss3-ditch-light-kit-for-2021-ford-bronco/
Assembled here in the USA (St. Louis, MO). 8 year warranty and we've got TONS in stock for immediate shipping. Much better quality then some of the cheaper solutions on Amazon. If you ever get tired of the output pattern you can also change the lens as well.
Ford Bronco Budget minded ditch lights 1643999249722
Wolfeman
Little Rock, AR
2019 F150 Raptor
These are probably the way to go for style and function and the price doesn't beat you down either. Plus you get a wiring harness and support from a company that also supports the forum. It's a win/win.
R11
Rob
Sparta, Tennessee
www.basequatch.com
Bronco Base Sasquatch 2.7
Plus mounting brackets and wiring harness. Once you add those in you are a lot closer to a (presumably) higher quality product. Admittedly i know nothing about cali raised but DD is a well known brand.
They’re $180 and a harness is $30. And that’s if you don’t wait for a promo code which they do regularly. You don’t need brackets. Fwiw I have them.
gtx_bronc
GTX
I was just pointing out that you aren't comparing apples to apples from a cost perspective. Of course it is cheaper when it comes with less stuff and is lower quality with a much shorter warranty. The fact is the DD are a great deal for the quality, contents, and the cost.
theguda
IN
2013 Ford F-150
Can you get amber covers for these to snap on during foggy/snowy weather?
4x4TruckLEDs.com
Adam
Lindenhurst, NY
webspoke
Stan
Pilot Point, TX
F450, GT350
I have these as bumper lights, but they would work fine for ditch lights. $99 for Solid construction, very nice harness, and cool amber backlight. Beam pattern and throw is short for a driving light, but would be good for ditches.
Rough Country 2" pods
Ford Bronco Budget minded ditch lights 51624893662_5520ea0b67
theguda
IN
2013 Ford F-150
4x4TruckLEDs.com
Adam
Lindenhurst, NY
How well do the covers perform compared to just buying the yellow lights? Would you say they're 75% as effective? More? Less? Just curious.
Not 100% sure. There is a bit of loss of light since it's going through a 2nd lens system now. Also, it's not a YELLOW diode going through the lens.
Diodes Dynamics white lights have white LED diodes going through white lenses
Diode Dynamics yellow lights have yellow LED diodes going through yellow lenses
So you'll be taking a white light, going through a yellow lens and it won't be as good. THEN AGAIN you'll have MORE light (the white LEDs put out a bit more light over their yellow version).
To give you an idea, my SS3 Max that are on my own bronco, they are actually SS3 WHITE lights but i've put the YELLOW lenses on, as i wanted THE MOST light i could get (not street legal though anymore).
Sooo if you want yellow lights, get them from the start that way.
If you want white but want to experiment with the yellow, get the covers and/or a spare set of lenses to play with.
mybikeisred
Paul
Carmel, CA
F250 Powerstroke, Grand Cherokee
I just ordered a set from you. Am I gonna have any issues with the antenna?
4x4TruckLEDs.com
Adam
Lindenhurst, NY
AmericanYidiot
Boston, MA
2023 OBX 4-door
This is probably a dumb question, but I just don't have much experience with this. How difficult would these be to wire if I don't have the Aux switches in my Bronco? I'm assuming at the very least I'd need to drill and install a switch in the dash...
4x4TruckLEDs.com
Adam
Lindenhurst, NY
You'd need to connect the included harness to your battery and then run the included switch into your cab (through the firewall) and find a place to install the switch on your dash.
AmericanYidiot
Boston, MA
2023 OBX 4-door
Again probably a dumb question, but do the lights come with install instructions/diagrams that would help with that? Thanks!
