Moto26
Tucson AZ
Yeah, it sure does. I rented a van instead, a Penske Van. Screw Uhaul...
What a stupid policy. I've never heard such a thing. 🤪
You should pull a "Pretty Woman" on them, and drive into their lot in your Penske van and say, "Remember when I tried to rent a trailer from you the other day and you wouldn't do it? Big mistake. Big. Huge!"
Thurmy7
Kevin
Fullerton, California
Suburban, Tacoma, Patriot
I didn't get a chance to weigh the tongue before taking the boat back to storage in Needles, so I'll have to weigh it later this year. I assume its in the 450 pound range, but I really do need to get an accurate measurement soon before I tow too much with the Bronco. We've got a Suburban we will use most of the time, but I know I'll use the Bronco on short trips.
I actually just weighed on a truck scale this morning. The tongue weight is right on 450. The overall boat weight though is almost 5,500... so I guess I won't be towing with the Bronco much.
bobplastow
Bob
Mitchell, SD
66 Mustang, 66 F250, 22 Bronco Badsquatch, 23 F150 Lightning Lariat
Ford Bronco Broncos Pulling Trailers Pics - Add Yours 01A0429F-B721-4E36-893E-13ECAE82030E
Ford Bronco Broncos Pulling Trailers Pics - Add Yours 87AE9DBA-5625-47C5-AD5B-91D74F615E87
6x12 v-nose cargo trailer turned into basic camper. About 1900 lb empty weight. 250 lb tongue weight.
Datoad
Fontana, California
06 Jeep LJ Rubicon, 17 Mustang
Just pulled the boat out of the garage to test run on the garden hose.
The wife had the truck so I hitched up the Bronco!
pulled it out and back in with no problem!😎
Ford Bronco Broncos Pulling Trailers Pics - Add Yours 297EB635-B771-4A8E-9181-8CE1E2A56940
Go Devils
Reed
Got any pics of the hitch you’re using? I’m trying to visualize the difference between a “hitch extension” and an “extra-long hitch”…
FYI if you’re looking for the perfect size that clears the spare.
CURT 45260 Class 3 Trailer Hitch Ball Mount, Fits 2-Inch Receiver, 7,500 lbs, 1-Inch Hole, 2-In Drop, 3/4-Inch Rise https://a.co/d/6kTVPw0
Go Devils
Reed
Go Devils
Reed
That has been a thing for Uhaul for several decades. Welcome to soft top ownership. Kind of sucks.
But only soft-top SUVs! Soft top sports cars or coupes seem to be ok with UHaul. Go figure! Probably stems from the roll-over prone Suzuki Samurais from the 80s !
NC_Pinz
NC_Pinz
Central NC
2022 Ford Bronco OBX w/ Squatch, 1975 Ford Bronco
Tricky Dick
Dick
PNW
www.TD-Distributing.com
What you doing with the International cab? Something fun?
Very fun. It's getting pasted to this and going on a E450 frame.
Ford Bronco Broncos Pulling Trailers Pics - Add Yours PXL_20220723_175509574
