Bronco Wishlist to Ford
rmc523
South Florida
2022 Bronco Wildtrak
I have access to Solidworks at work. Not a CNC machinist. Just a Quality Engineer.
But honestly, you may be able to do that in Adobe Illustrator (which I have at home).
Illustrator would certainly be able to create the pattern of the Bronco script for a CNC machine. Might have to save it in a file type the CNC computer can read if it can't read something like an .eps file, but that's easy.
lobbs611
Kyle
Independence, MO
2D JL Rubicon
Ahh, I've known people who've had decal work cut on a vinyl plotter done from Illustrator .ai files. If you wanted actual metal badges made I could see the need for CNC work.
rmc523
South Florida
It'd also depend on the complexity too - something that had depth would require something 3D like Solidworks (which I used at work too), but Illustrator would be able to give you the pattern for flat things.
Grave Digger
Channel Islands
Grave Digger
My wish is a factory snorkel for deep water crossings. Just with the alternator was mounted higher, may have to go 37's and even more reason to squatch for gearing.
mismith
‘16 Jeep JKU, 1992 Jeep YJ, ‘71 F100, ‘02 F350
Premium Twill soft top as an upgrade from the cheaper vinyl tops like Jeep offers. Also, please, please, please offer a factory soft top for the 2 door!
Trust me on the soft top materials. I'm a long time Jeep owner. I've always had soft tops. The cheaper vinyl tops by Bestop are noisy and cold/hot.
BUT...The Premium Twill tops are the most awesome soft tops ever. Absolutely Zero road noise even at highway speeds. No hot/cool issues. It's an amazing material that is every bit as quiet as any hard top but with the freedom a soft top delivers!
Deadfish
Idaho
2006 F350, 2007 HD Road King, 2013 370Z
Grabber (or similar) blue and white hard top is an absolute must. More mix-and-match interior options between trims would be sweet too
Rufus
Paul
20 Explorer Platinum
I concur and I'll raise you a white grill. A white top and white wheels are historically accurate and very handsome. As a bonus a white top reflects heat better and doesn't fade.
You NAILED it RIGHT ON! This is what I want (but in a classic Heritage color).
