Bronco Stranded
beachrat
Rick
2023 Bronco
Hi b's,
I have a 2023 Bronco and it won't go into gear. The motor runs fine at park, when selected for
drive or reverse, a light flashes on the d or r selector buttons, and the Bronco won't respond.
Its like a safety something won't give gear selection. Yes all doors, hatch, closed. I would like to look for
a code, does anybody know where the computer hookup for that is? thanks Bronco is getting restless!
Rick
PWillette
Parrie
Maine
Haven't heard of this issue. Is it not throwing any messages/codes on the infotainment screen? OBDII port is located driver side just under the dash on left hand side of steering wheel.
swooshdave
Portland, Oregon
Mustang
Hi b's,
Rick
Foot on brake?
Ford Motor Company
Official Ford Account
Dearborn
Bronco, Bronco Sport
Hi b's,
Rick
Hi there, I'd be happy to look into your Bronco concerns on my end. Will you send us a message with your VIN and dealership info? I can look into things on my end.
beachrat
Rick
2023 Bronco
thanks
beachrat
Rick
2023 Bronco
thanks
da_jokker
Jeep Wrangler JKUR
Have the keys? The bronco won't let you drive it if it doesn't sense the key.
beachrat
Rick
2023 Bronco
found it thanks, had to take a short trip to the hospital so I'll have to wait on computer checks!
beachrat
Rick
2023 Bronco
like I said starts fine, idles fine, when you select drive or reverse the light flashes and won't go in gear! 2023 bronco!
da_jokker
Jeep Wrangler JKUR
Are you using a "my key" ... At least I think that's what it's called. It's that programmable restricted key that can lock you out of things.
But the fact that you're able to actually move the shifter makes it sound like it's an electronic problem.
