Diabolical Inc
Lux Sponsor (Level 2)
shop.diabolicalinc.com
2020 Rubicon, 2021 Bronco Wildtrak
You asked, we delivered. Check out the teaser for the all new Bronco Stage. This 2 piece platform is perfect for leveling the back of the bronco for sleeping, and still gives you access to the floor storage.
This should be available for preorder soon
Full Video:
Mike T
Brandon SD
2023 Ford Bronco
Looks great! Will there be tie downs on the top?
  • Like
Reactions: cbs
Diabolical Inc
Diabolical Inc
We have had a few people ask and thought about it. The idea is for more of a sleeping platform and tie down might be uncomfortable.
The other thought would be to mount your D-Rings on the top since they wouldn’t be any use underneath.
cracKen
Washington
23 Bronco Badlands 7MT
Been trying to figure out how to sleep in my Bronco on some trips. This might be the solution.
Odd Ball
Cali
HD Vett Mustang Jag 911 (2)450SLs VWcab Blzr Fiat
Nicely done, but I’m not fond of the front gap/ pool noodle solution though. Also thank top d-rings would be a good addition.
  • Like
Reactions: cbs
Bellime
Keith
2022 Ford Bronco
Full Video:
I would like pre-drilled and tapped holes to install tie-downs as needed.
  • Like
Reactions: cbs
Bellime
Keith
2022 Ford Bronco
Otherwise I will be on the list to purchase this.
  • Like
Reactions: cbs
Bellime
Keith
2022 Ford Bronco
Full Video:
I would also use cupped washers to recess the bolt heads on the bracket mounting. This makes the underside a smoother surface to store stuff underneath
Braaap
Outback
Interested and following!
Bellime
Keith
2022 Ford Bronco
Full Video:
I maybe would add a hinge and flap to the front top section to use as a cover for the gap when seats are folded forward. Make that a split flap, maybe
