Bronco Running down while towed
stokesrl
Bobby
tennessee
2023 outer banks
I’m towing my 2023 2 door behind a motorhome. I have a wire running from the charge wire from the motorhome
To the positive terminal of the battery (with a diode between). I measure 14.6 volts from that charge wire into my battery. My issue is that the battery runs down while I’m towing it. I left with the battery at 12.6 volts and within an hours, it was 12.1 volts.
I never hit the brakes, so the stay in play isn’t running it down. Surely the computer while in tow mode can’t be drawing more that the camper can deliver?
Any ideas?
grtharris
Grant
Skiatook, OK
Outer Banks 4dr, 2008 Mustang GT CS (Wife's), MH
Right off it sounds like you either have a bad connection on the positive or negative side of the battery. 14.6 volts is high at the battery if Bronco battery is pulling any current from the coach there should be some voltage drop in the wiring.
Now why is the Bronco going down. First guess is a bad battery should not drop that fast.
Travler
the hills of idaho
1970 bronco 2021 Wildtrak
Like the other Gentleman says , I would all the connection even the Ground on Motor home
Bill K
Bill
Allen, TX
Ford Bronco Big Bend 2 Door
Any ideas?
I second the inspect all connections advice. I have seen the connection cable ends I use from Blue Ox be a little intermittent sometimes. Note that on the Bronco connector, the wires are secured by screws into the stripped wire. An ohm meter might come in handy as you likely have a high resistance either in the charge or ground return line... A good piece of long wire to run in parallel to use your meter will help diagnose with everything connected and the connection at the battery disconnected and the fuse pulled in the motorhome for the positive side anyway.
BadlandsA51
Craig
Kansas
23 Badlands, Sasquatch, Lux Pkg, 72 Ranchero GT
You mentioned being connected to the B+ terminal, but didn’t mention how you connected the negative terminal. It must have a good connection to the same ground as the towing vehicle’s battery. No ground, no current flow, no charge.
stokesrl
Bobby
tennessee
2023 outer banks
It has 4000 miles and is just a few months old- but I guess a bad battery is possible- although it starts flawlessl
i need to check- I’m sure it’s connected to the ground coming through the coach connection- but maybe I need to run a ground from there directly to the battery
BadlandsA51
Craig
Kansas
Or you could just hook everything up and measure voltage between the Bronc’s battery negative terminal and tow vehicle’s negative battery terminal.
Turn the Bronco’s key on, and the lights and heater blower without starting the engine, this will load the charge circuits. You should measure 1V max between the two batteries negative posts. You could run the same check on the positive posts of the 2 batteries. It should be less than a volt also. The lower these voltages, the better.
stokesrl
Bobby
tennessee
2023 outer banks
I assume it’s ok ( or necessary) for them to share a ground
BadlandsA51
Craig
Kansas
Yes, the tow vehicle will be the charging system for the Bronco. The Bronco’s battery has to be grounded to the tow vehicle, just like the tow vehicle’s battery is grounded, otherwise no current will flow through it.
