Ninjak
Miami
From what I have read and seen, most of the "breaking" of the tie rods has been when people lock up the front and start trying to steer the vehicle up rocks. The break comes from the binding of the system. Talking to very experienced off-roaders, I was told that when you pick your path, go straight, or not to engage the front lockers unless you have a need, and then go straight without twisting back and forth.
With all that said, I will still upgrade my rods to the fabtech ones, also I doubt that I will get into any type of hardcore crawling or rocks here in S. FL, but as they say, it's better to have than have not. Since the Braptor already has an upgraded rack, I think it may be fine even on the 40's I guess we will find out through this @DentonDreamMaker content :)
Jdyount
Jason
Kansas
2021 Badlands
Everyone said the same thing when I put 37s on my Outerbanks & I went off road al the time with no issues.
Guess only time will tell.
I think you'll be fine with light wheeling but you will run into issues if you do any harder stuff. I'm not worried so much about the steering or the CVs with the B-Raptor (being wider you get better angles). The gears or axle shafts are going to be what breaks. Too much power and too much rotational mass. I watched a guy in a hemi swapped JK on 40's pop a rear axle shaft on a Dana 44 like it was nothing a few weeks ago.
I'm running 37's on my Badlands. Would love to go to 40s but I'm going to wait until I can afford portals (which takes to load off of the axle's internals, among other things).
Turbo yzel
DMV
Braptor
Website says 104 lbs per tire
Don’t know wheel weight
Interesting to see how time will treat the axle n bearings, ball joints, etc 🤞
Breptar
Max
Los Angeles, CA
toyo and nitro are my tire of choice, but unfortunately the tires weight is what swayed me away from them for the braptor.
Broncotrax
NORCO
69 Bronco, '17 Superduity, '22 Badsquatch, CR 250R
DVNT6129
Josh
ATX
2023 Braptor
Did you read her first post?
Yep sure did, did you read the post that my question was in reference to? Last I checked her first post doesn’t say anything about her spare, how she mounted it, or if she’s had any issues with it. But thanks for your smart a$$ response, super helpful
Troybuilt
Troy
Provo Utah 84601
2024 bronco raptor
Might be the baddest rig I've seen posted here. Makes it so much radder that there's a petite/pretty lady behind the wheel. We are all jealous!
Ford Bronco BRONCO RAPTOR ON 40's 20250418_100657
Sorry, you can't see the pretty lady. 40 inch Super Swampers on bronze method 17s. 2 in collar lift.
MuddyWaters
2025 Bronco
Apologies on if I missed this being asked earlier:
Have you had the opportunity to test the droop on these big tires yet?
I am sold on 37s at the moment, but am curious as to how the suspension system reacts when 40s are thrown on.
Georgelas
Aaron
Vienna Virginia
1974 Ranger, 2021 First Edition, 2025 Outerbanks and 2023 Raptor, 2025 GT3 RS,
What is the overall height after the upgrades? Are parking garages out of the question?
