It must have nanobots. Never trust nanobots.No thanks. It has "regenerative breaking".![]()
I ran across this article this morning...
https://www.yankodesign.com/2020/12...nvert-your-vintage-automobile-into-an-ev/amp/
Sometimes it makes sense to do that as parts may no longer be available. It might be the same thinking as swapping a coyote 5.0 into an older Bronco. The older engines didnt put out as much hp either. Blasphemy would have been to put a 2.3 turbo in one of those older Broncos.......but we are doing it today.I can appreciate EVs for their purpose. I don't like classics being modernized in such a fashion. There's plenty of other vehicles out there that are better hosts that don't carry a history or tradition with it.
For the same reason, I don't like seeing a numbers-matching '69 Camaro Z28 being torn down and turned into a purpose-built drag car with a big block, roll cage, sectioned rear end and massive slicks.
I drive all sorts of cars. And I have to say that generative breaking is my favorite feature. One peddle driving is really cool. Took a little to get used to it, but it’s a nice way to drive.No thanks. It has "regenerative breaking".![]()
If all the cars were EVs, they would be at scale and cheap. And you would have a charging infrastructure so you can charge in 5 minutes. For this argument to hold, you would have to compare EVs with 100 years of development to brand new ICE cars. Which means there would barely be any gas stations, etc.
Nor does this...It would sound insane to folks lol. EVs obviously are not perfect, but this argument doesn’t hold water.
That's like saying "if all cars had carbon fiber wheels like the GT350 had they would be at scale and cheap." Never going to be the case. Same with electric.If all the cars were EVs, they would be at scale and cheap. And you would have a charging infrastructure so you can charge in 5 minutes.
Try finding new aftermarket or good used early bronco rear lift glass latches. Unobtanium!!Sometimes it makes sense to do that as parts may no longer be available. It might be the same thinking as swapping a coyote 5.0 into an older Bronco. The older engines didnt put out as much hp either. Blasphemy would have been to put a 2.3 turbo in one of those older Broncos.......but we are doing it today.
You can get an EV that goes 260 miles on a charge for $23k. How cheap do you want it?Nor does this...
Difference I could drive any old car with maintenance and repairs done, fixing issues as I go alongIf all the cars were EVs, they would be at scale and cheap. And you would have a charging infrastructure so you can charge in 5 minutes. For this argument to hold, you would have to compare EVs with 100 years of development to brand new ICE cars. Which means there would barely be any gas stations, etc.
So, ICE would not do so well. Plus, you would have to tell folks that, now all you have to worry about is oil changes, gaskets, transmission failure, more fluids to upkeep, etc…. And you would have to set up an infrastructure to get liquid gas to all the stations on a regular basis. It would sound insane to folks lol. EVs obviously are not perfect, but this argument doesn’t hold water.
I couldn't agree with anything more than this statement. I live in a very rural area and until they perfect the solid state battery and make driving an EV more like a normal combustion engine it will never take off especially out here. Funny enough what they have to do to get the material for the batteries produces more emissions than a normal combustion vehicle over its lifetime. I can't wait to see how this all goes.I wonder if they could ever offset the emissions it took to make this?
These are all stunts until battery tech improves by orders of magnitude.
EVs are the new Haliburton-esque war mongering and profiteering. They set an idyllic goal no reasonable person could argue without being villainized with a promise to achieve it... if only they keep getting more money and support. The catch, of the goal, is similar to achieving world peace... the money dries up as soon as you achieve it.
Can't wait to see it out on the Rubicon!
