WobblyWillie
Nebraska
C6 Corvette
Nice job. I am working with Greg about doing a custom for my Wildtrak. Did you do/install the hood graphic for this kit?
Thanks! Yes, I did.
Due to rushing the install, I had a couple of decent imperfections near the driverside windshield washer nozzle, but a little heat from the sun worked them right out for me!
Ford Bronco Bronco "Braptor" graphics kit: photos and info PXL_20230527_171844373~2
Ford Bronco Bronco "Braptor" graphics kit: photos and info PXL_20230527_171725787~2
Ford Bronco Bronco "Braptor" graphics kit: photos and info PXL_20230527_171652940~2
Underground Graphics
Greg
Houston
www.undergroundgraphics.com
22 Bronco, 20 Jeep Gladiator
BigHoof
PA
Ram 2500
Do you have any customer pictures of this design installed on an EG Bronco? Guessing the orange kit would be best for that color. The gray kit may work as well sort of coordinating with the grey SAS wheel rings. Thanks!
Greg
Houston
we do have a photos of the Black Gray kit.
Ford Bronco Bronco "Braptor" graphics kit: photos and info Braptor Eruption Green
CAFERACER
CHRIS
LOUISIANA
2023 BRONCO
WOW!!! A $172 increase in a year and half for sides only?? Holy cow!
Greg
Houston
Last year in March we had a long overdue price increase, basically across our entire line of vehicle graphics. It's ridiculous how much these quality materials go up; sometimes multiple times a year from 3M. However, we also added some great things like IPC coverage at no cost and are currently running a 15% off sale. Let us know if you have any questions, we'd be happy to discuss!
Greg ;)
CAFERACER
CHRIS
LOUISIANA
2023 BRONCO
Greg ;)
dISCOUNT helps.....
purchased the side braptor graphics, orange headlight kit and prep and slide spray. Hopefully I dont screw it up on the install
Greg
Houston
dISCOUNT helps.....
You won’t need that slide spray, unless you’re adding a PPF screen or other wet install piece. The Braptor kit like all our vehicle graphics are made in wrap vinyl which is DRY install. Be sure and watch our YouTube install video. Also, on the bad luck you mess up a piece, we do have you covered. Just follow our IPC plan guidelines and you’ll have a replacement piece. Once you receive, open it all up, lay it flat, make sure you have a plan and if you have any questions or concerns, please call us BEFORE, you install!
Greg😉
