Bronco big bend (standard bumper 2025
BroncoCLE
Cleveland ohio
Bronco big bend
Is there a plug n play fog light ( assume it connects in tandem with headlight)
Any other fog lights need to aux switc correct.
Just trying to get some fog lights without tons of mods yet
or should i just get new bumper with headlights.
Muffin1
Rob
NJ
'25 BB Carb Gray, & '25 Ranger XLT Azure Gray Sport 4X4
I'm in the same boat with my BB i want to add the fog lights, there are a lot of threads on here and trying to sift through them all.
From what i've learned so far there are no wiring to tap into so you need to do that from scratch and then hook it up to a switch, if you have the upfitter switches you can use one of those, my uncertainty is which exec fog light kit to get, there's a lot of different choices. :confused:
helifino16
Ron
Mount Sinai, NY (Long Island)
If yours didn't come with Fogs, you'll also have to replace the Headlight switch to incorporate them like stock. (I believe this requires a ForScan trick as well to get it working). It's WAY easier to connect something to an upfitter switch (or separate switch in the absence of these).
@MandRautomotive has a light bar solution for the Standard Bumper that you can have Amber/White to accommodate most needs (Fog/Off-Road/etc.). Here's mine (see the Bar, not the Factory Fogs):
Ford Bronco Bronco big bend (standard bumper 2025 Blue Lights On
