Bronco Badlands AC intermittent
rhalama
Richard
Georgia
Bronco sasquach
Just looked under the hood of my sons 2022 Bronco and what a suprise--Never gave up on a car repair until now. All my life I fixed my own vehicles and now that I am 81, I slowed down. His AC would work one day and not the next--disconnect the battery and it may work or not. Did my research and could be clutch not engaging due to lo pressure defective switch or lo refrigerant. I can't even find the compressor with all the pipes, wire and hoses, let alone the lo pressure switch, so I was changing tactics and measure the refrigerant pressure with my gauges (I am not a AC guy but do have gauges). Could not even find the lo/high preesure connections. Any one can take a photo of the location of the compressor so I can see if the clutch is engaging and the location of lo pressure switch and hi and lo pressure ports to check pressure?? Thanks in advance
Ducati1098
Low side: Drivers side, back of the engine to the right of the valve cover.
Ford Bronco Bronco Badlands AC intermittent IMG_1982
High side: front of the engine, drivers side, right behind the fan.
Ford Bronco Bronco Badlands AC intermittent IMG_1983
You can follow both lines down to the compressor. Pressure transducer will be at the bottom of the high side line.
rhalama
Richard
Georgia
Bronco sasquach
Ducati1098, thanks so much. Great photos and descriptions.:clap:
rhalama
Richard
Georgia
Bronco sasquach
Do you know if the lo pressure switch is mounted right on the compressor or near it on the lo preesure pipe. I've done of looking but you have the best instructions---thanks
