Bright Black Front Grille Replacement
Jason-Ecarzo CEO
Bronco, Ford F150
Hello everyone,
Today I'm announcing good news, Ecarzo released a 10% discount on Ford Bronco Front Grille Cover. Click the link below to get it. It is valid for 2 weeks.
https://www.amazon.com/gp/mpc/A3NTPAOTQOYRON
Which makes it looks like a high-end version of Bronco, better adorning your Bronco's exterior.
Are you sure want to miss this discount?
Ford Bronco Bright Black Front Grille Replacement 1
Ford Bronco Bright Black Front Grille Replacement 8
chownd
J
Boston
2022 OBX
You might want to get some pics on a real bronco. Those Photoshops and the lightning of them will probably dissuade buyers who don't recognize that's what they are
IwannaGOfast
Jon
Brea, CA
2021 4 door Badlands, 1991 Ranger Long Travel, 2014 Cruze Commuter
Does this grill work with the front camera?
Compta38
Alabama
Ford Fusion
want basically a BD grille with camera, flat black.
ThisGuy611
E90 M3 6spd Sedan; EG Base Scheduled 3/27
White letters included?
Jason-Ecarzo CEO
Jason-Ecarzo CEO
Bronco, Ford F150
Thank you for reminding me, I agree with you very much, I will really bronco pictures in the future.
MannyG20
Ted
F-150
Looking at the pictures on Amazon it doesn’t look like it has an opening for the camera. I am going to look at my grill today and see what modifications would need to be done to make it work.
MannyG20
Ted
F-150
This is what I want too. I was going to paint my existing BL grill but the auto paint shops I have talked too have said that in their experience using flat paint has two drawbacks that down the road customers complain about. 1) Flat paint fades more more quickly than gloss. So your beautiful flat black grill will look faded fairly quickly. 2) flat or satin clear coat chips more easily than gloss. Not a big difference but something to be aware of.
Because of this I am looking at gloss black. I may have to be the guinea pig and try this grill out. 😬
MannyG20
Ted
F-150
I took my grill off and took a look at the camera assembly. The assembly looks like it can be removed and attached to another grill that does not have one.
I do think you would need to cut the plastic between the ‘O’ and the ‘N’ and slide the camera into this position. If the grill is not made to accept the camera you would probably have to drill out hole for the anchoring screws or you could do 3M double sided tape to attach the camera. You will also have to deal with running the optical cord and water supply to the camera.
it sounds like a lot but I think it is easily doable if this grill is not already equipped for the front facing camera.
also, it only takes about 15 minutes to remove the grill. You could just swap out the grills when you go off roading. Not the best solution but again doable.
4avor8ntfair
Houston, TX
BL-non SAS, 2.3 auto
Hello everyone,
Is this a “grille” that replaces the existing grille, or a “grille cover” that goes over the existing grille?
