- Todd
- Jun 10, 2021
- 69
- 468
- 1,835
- Chandler, AZ
- Website
- www.doetschoffroad.com
- 2021 Badlands 4dr, 2021 Wildtrak, 2021 Rubicon 392
- Badlands
Brian's brand new 2dr 2022 Ford Bronco Badlands is stunning in Carbonized Gray, and our upgrades feature a strong list of performance and functional changes.
We started with a Fabtech Motorsports 2.5 Resi Dirt Logic front and rear coilover system that includes new front upper a-arms and rear adjustable lower control arms. After tuning the suspension, we easily fit a set of 37" Cooper STT Pro mud tires on 17" Icon wheels which feature "bead locking" bolts that help keep the tire from separating from the wheel at low air pressure. A set of Fabtech's aluminum tie rod ends featuring HEIM joints, as well as a BroncBuster bushing kit, will ensure the front end stays together while riding the Bronco on rough terrain. To keep the spare tire in check, we installed a Hammer Performance reinforcement bracket with holes for future accessory mounts.
Next up, an ARB on-board dual compressor kit was mounted under the hood along with a manifold to cleanly route a quick connector for inflating tires, air mattresses or whatever inflatable you need at home or on the trail.
Up front, we installed a Rough Country hidden winch mount which utilizes the factory steel modular bumper, but allows for a trick spot to get a 9500lb winch installed where the factory lower skid plate sits.
For lighting, we used a set of fog pocket brackets to mount the customer supplied Rigid LED lights, as well as a new 20" Rigid SR-Series Pro Midnight Edition light bar under the overrider bar, as well as a pair of LED Sideshooter lights at the a-pillars. Finishing off the wiring was adding a set of "Raptor Style" amber LED lights to the grille.
