Braptor Flat Tow Wire Harness?
Bukin67
Randy
Southeast of Disorder
'67 Bronco Baja racer "The Bukin'eer"
Luckily, the Braptor comes with tow bar attachment points without needing to purchase aftermarket or fab them up. The only thing missing is the lighting hookup. Has anyone found a plug and play wire harness for flat towing the Braptor? A couple pop up searching but none specify the Braptor. I saw Curt has one for the 6g Bronco on etrailer, but I don't know if it would use the same one. I've got a set with magnets, but I don't want to use them on it. I would rather do something like dusty did in his Horsin Around vid from last years Super Cel West:
Bronco2025
Los Angeles
Jeep Wrangler
Subscribed. I need to get mine setup too. Likely just run wiring externally to a set of lights mounted on a bike rack.
