Brake light fuse(s)
GunninGopher
San Diego/East County
2021 OBX 4Door (wife's), 07 Silverado 2500 LTZ 4x4
So I've looked at the fuse assignments for both the under the hood and under the steering wheel fuse boxes. Here is my resource:
https://fuse-box.info/ford/ford-bronco-2021-fuses
I cannot locate the one for the rear brake lights. I've been getting jerked around trying to install a Curt wiring harness and now all of a sudden the right brake light is out. In my troubleshooting I'd like to check the fuse, but I can't figure out which one it is.
PepSek
Jake
Hello,
Did you ever figure this out? I was having issues with my upfitter switches so I took it into Ford and I spent $400 for them to tell me where my fuse box was and after I left I discovered that my brake lights only work half of the time
AM1217
Lakeside
2018 Harley Davidson Ultra Limited 115 Anniversary
so did you find the fuse ? and what was the fix ? I have the same issue.
Ducati1098
Brake lights don’t have a fuse. They use a FET internal to the BCM.
AM1217
Lakeside
GunninGopher
My problem ended up being the harness plugs really couldn't stand much wiggling. I had to re-seat a few of the wires. It's been a couple years so I don't recall exactly what it was, other than a pain in the ass that would not have been had Curt built the harness correctly and/or actually believed me when I told them there was a problem.
