Body height. RR higher than LR
Silver-Bolt
Bill
Eureka, MT
How much fuel in your tank?
Ts3794
Ron
Reno
Jeep
Full on first post. 1/3. Today
Same basic measurement.
Fuel fill is on left (drivers) fuel tank mostly on right (passenger side)
So full tank should make it less
Silver-Bolt
Bill
Eureka, MT
Are the springs seated correctly?
Dads_bronze_bronco
08 JKUR / x_x 00 TJ x_x
please don't say left or right. please say driver or passenger side.
So gas tank is on passenger side and on some cars with a full tank, the PS will sit lower.
In another world it is called the Jeep-lean....
Dads_bronze_bronco
I also own a Jeep. JK.
And will have both Jeep, and bronco in same stable.
i don’t see lean in my JK,but understand your reference.
When I took off my stock Rubicon springs the front springs were two different part numbers to account for the passenger side swaybar disconnect and gas tank. The OME lift kit I put on came with 10mm trim packer spacers. I have one on the passenger side in front and later one in back to level it side to side.
I would guess on the Bronco, with a driver in, it may be close to level.
Agree with others though, I would check the spring seating.
Ts3794
Ron
Reno
Jeep
When I took off my stick Rubicon springs the front springs were two different part numbers to account for the passenger side swaybar disconnect and gas tank. The OME lift kit I put on came with 10mm trim packer spacers. I have one on the passenger side in front and later one in back to level it side to side.
Driver in unit, would make it worse. Drivers side is the low side.
but I understand the fuel level, driver questions
