Blend Door Actuator - 23' Black Diamond
JJohnsonx21s
Jeremiah
Maryland
2023 Ford Bronco Black Diamond 2.7L
Good afternoon, All,
Our 23' Ford Bronco Black Diamond 2.7L V6 has cold air blowing out of the drivers side vents, no matter the setting. Took it to a service shop and they told me it's the Blend Door Actuator. From my search, Ive seen there are three. Does anyone have a clue which one operates which sections? Thank you!
Ducati1098
Which climate control system do you have? I’m assuming you have the dual zone automatic system if only your drivers side is cold?
Ford Bronco Blend Door Actuator -  23' Black Diamond IMG_9334
JJohnsonx21s
JJohnsonx21s
Jeremiah
Maryland
Yes! It’s a dual zone. And if I am looking at this correctly the driver side actuator is on the passenger side of the bronco?
Ducati1098
It’s more so in the middle, but it is on the drivers side of the climate control housing.
The left picture in the diagram above is basically the view from the drivers seat if you could see through the instrument panel. The actuator you’re looking for is #4
JJohnsonx21s
JJohnsonx21s
Jeremiah
Maryland
Awesome! Thank you!
