Black Diamond - renderings from different perspectives
Rogues Gambit
Eatontown, NJ
'19 Ram Rebel, '07 A4 Quattro
In Frisco, that is about 25 miles North of Dallas. :)
Perfect, pray I can actually stick with plan A, wanna go in September
BroncoFanBoy
Brandon
Az
Nissan
Part of me hope sasquash is $$$ to make me upgrade to BD and just add 35s/lift
chances a leveling kit is all that’s needed to get 35/ on a non-sas?
mxmerce
mxmerce
2018 Ford 150 Sport 4X4
From what I understand you need more than a leveling kit. The Sasquatch comes with the lifted suspension(2.5" suspected), however it also requires(and comes with) larger fender flares, for clearance during articulation. So without the upgraded fenders, I think(not sure) you'll need a 3" lift or better.
NVCowboy
William
Henderson, NV
2002 F350. 2022 Big Bend (Sasquatch)
I’m liking how you managed to drop the trim level I want in the middle of what I plan on being the Bronco’s natural habitat. Great Basin juniper and pinion pine “forest.” It looks good there, but I want a four door.
mxmerce
mxmerce
Here you go my friend.
Ford Bronco Black Diamond - renderings from different perspectives black_diamond_rear_driver_4_door
Tdubz
T
F
I don’t mind the gray hard top. With the right options/trims, I think it will look pretty good. The optional wheels on the badlands have a gray ring which kinda matches the top. Also the big bend trim has the gray grille and gray wheels which should match pretty good with the top as well.
Ajusaf
AJ
VA
I might keep the steel rims unless I go with BB instead of BD and those are gray rims, but I thought of painting the grill letter BRONCO in gray to match the gray top
Zinn
Minnesota
2016 Mustang GT, 2020 Ranger Lariat
I think the gray top will look great with Area 51. I was worried about the stance from those slightly-less-than-32” tires, but it looks badass, especially with those steel wheels.
Nice photoshop skills!
mxmerce
mxmerce
Ford Bronco Black Diamond - renderings from different perspectives black_diamond_colorado
mdonathan56
2022 Bronco Bad,2016 Q5 TDI, 2009 Honda Element EX
BD with the Sasquatch package and call it done. Except for color; just can't decide om Oxford with the black accents or AM or Carbonized Gray or A51.
