Different Trims with 33s and Sasquatch Renderings
mxmerce
mxmerce
2018 Ford 150 Sport 4X4
Bad-Squatch Area 51 - Accessorized:
Ford Bronco Different Trims with 33s and Sasquatch Renderings badsquatch_area51_acc
Added a little more blue to the color. (Whited out the Bronco logos)
Yosef
Orlando, FL
Toyota 4Runner
Thanks for doing this! Seeing the 33s makes a big difference. Amazing what the next tire size up can do purely from an aesthetics standpoint. Also, good to know that 33s can fit without a lift.
BroncOBX
Rick
NoVaStan: Land of the Petulant
www.polaris-intel.com
2012 Ford F-150 FX4; Mavic 2 Pro
Here you go, looks good.
Outer Banks (Factory):
Outer Banks 33s:
Outer Banks 35s(Sasquatch Package)
After reading a bunch about tire sizes I have shelved my Sasquatch plans and leaning towards 33s on the OBX. But...stock are 32s and the only published option I've seen are the Squatch 35s. Will 33s be a Ford option?
Garemlin
Delaware
Still thinking 33s give the best look and stance.
mostly harmless
Austin, TX
2012 RAM 1500
After reading a bunch about tire sizes I have my Sasquatch plans and leaning towards 33s on the OBX. But...stock are 32s and the only published option I've seen are the Squatch 35s. Will 33s be a Ford option?
As far as I can tell, no. None of the marketing materials so far suggest it will be an option. Though I really wish 33s would be an option across all trims.
GToddC5
Todd
South Jersey
www.bronco6g.com
Not sure if brought up elsewhere, but I don't think the Ford.com render has the correct front bumper, for Badlands
mxmerce
mxmerce
The only thing they've stated is that there will be 200+ accessories/modification that you can specify from the factory(ford performance). I'm holding out hope that two of those options are the wheel and tire package from the Badlands. ?
tshaw2009
Tony
Lebanon, MO
2011 F150 Lariat, 2018 Ford Edge Titanium
Personally, I wouldn't order a Bronco without the Sasquatch package or the factory 2 inch lift with 37s. Those 35s and 37s just make the Bronco look mean whether you ever need them or not. Now the one thing I think Ford could have done better is chosen a 35" and 37" M/T with a more aggressive tread pattern like a Nitto Mud Grappler from the factory or an aggressive X/T like the Atturo Trail Blade X/T. This is the way every Bronco was meant to look.
Ford Bronco Different Trims with 33s and Sasquatch Renderings 2021-ford-bronco-wallpaper
Treeza61
Richard
2017 F250, 2019 4Runner TRD Pro, 2013 FJ
Big Bend(Factory)
Big Bend 33s
Big Bend 35s(Sasquatch Package)
Black Diamond doesn’t come with 33s. Would have to go aftermarket. My choice is Nitto Ridge Grapplers.
Treeza61
Richard
The main problem I have with BD is the grey hardtop. I want black.
mxmerce
mxmerce
Ford Bronco Different Trims with 33s and Sasquatch Renderings badsquatch_area51_acc_cactus_gray_whit
