Big Green Badlands Build
swooshdave
swooshdave
Portland, Oregon
Mustang
I wouldn't hold much faith in that cover. They do make IPX6 components though.
I just need it to fight off the rain. I don't go swimming often.
NaMinesClarence
Northern Metro MN
2022 Badlands Sasquatch
I'll add some clarity, I use a cyclical corrosion chamber like this at work. We use it to test wiring harness and electrical component integrity. You'd be surprised where salt water gets even when a component is IPX6 rated. That being said, I would never test an Anderson with that cap if I wanted the product to function after the test.
Ford Bronco Big Green Badlands Build 1732398120837-au
swooshdave
swooshdave
Portland, Oregon
Mustang
I rarely see salt water.
swooshdave
swooshdave
Portland, Oregon
Mustang
Nevermind, you do you Boo.
Thanks, I was planning on that.
Since you noticed I live in Oregon and we don’t salt our roads in the winter you’d know that salt water intrusion wouldn’t be a concern.
NaMinesClarence
Northern Metro MN
You've obviously missed the point. That dust plug is not water tight. Water and electrical connectors are not friends.
swooshdave
swooshdave
Portland, Oregon
Mustang
So using your test device with plan water how long before the plug corrodes?
swooshdave
swooshdave
Portland, Oregon
Mustang
I finally splurged on a ghost antenna. Then went overboard with the mounting.
I started with a 3D printed temp mount while my SendCutSend order was on the way. It actually worked great.
Ford Bronco Big Green Badlands Build IMG_7357
Early Proto
Ford Bronco Big Green Badlands Build Screen Shot 2025-11-06 at 2.19.34 PM
Ford Bronco Big Green Badlands Build IMG_7384
Final 3D Temp Mount
Ford Bronco Big Green Badlands Build Screen Shot 2025-11-06 at 2.18.12 PM
Ford Bronco Big Green Badlands Build IMG_7628
Custom wrench for the antenna mount.
Ford Bronco Big Green Badlands Build IMG_7630
Ford Bronco Big Green Badlands Build IMG_7629
Extra tab to support the wire.
