Big Bend ground clearance?
The Driving Viking
Northeast
2022 Bronco Sasquatch 2022 Willys Xtreme Recon
The Base Bronco has a ground clearance of 8.4 with 30" inch tires. Does anyone know the ground clearance of the Big Bend? Im assuming its more being it comes stock with 32" tires.
kodiakisland
Arkansas
Depends on the actual size of the tire on the Big Bend. The tires on the base per Bridgestone are 30.5 inch. Bridgestone does not list the tire in the specs for the Big Bend, but assuming it's at most 32.5, then that would be one inch more clearance than the base, and it probably isn't that tall.
So my guess is around 9.2 inches.
The Driving Viking
The Driving Viking
Northeast
Yeah I figured it would be in the 9s with 32s. Im really stuck i don't know if i want to go Base+ Sasquatch or Big Bend.
I think someone said you can 33" for the Big Bend from the Factory. Im waiting for clarification on that.
Mopar2Bronco2021
Houston
2018 Dodge Charger RT 5.7L
Just add 1 inch to the clearance of the tire diameter is 2” greater. So 9.4 inches of clearance for the Big Bend.
The Driving Viking
The Driving Viking
Northeast
Is the suspension the same on the Big Bend and Base? If i went Base model I would like to add lower gearing and 33s if the Sasquatch package is too expensive.
Mopar2Bronco2021
Houston
They are the same suspensions but you can change them with options. They both come standard with 3.73 gearing but the Big Bend can be optioned with 4.47 gearing without the Sasquatch.
The Driving Viking
The Driving Viking
Northeast
So you can't option the Base with 4.47s without the Sasquatch?? If that's the case and the Sasquatch is too expensive I'm definitely going Big Bend.
Mopar2Bronco2021
Houston
Exactly. UNLESS you get the manual for the Base. If this is the case then your gearing is 4.46 standard. This applies to the Big Bend as well.
https://www.ford.com/cmslibs/conten...21/mediakit/21_Bronco_Prelim_Tech_Specs_1.pdf
The Driving Viking
The Driving Viking
Northeast
Dsauchelli2
Dean
Subaru Ascent
Has this been confirmed? Can you fit 33’s on a stock big bend?
mdepll
mike
toronto
sorento
I heard approx 9 inches too. No one knows for sure
