BESTOP TREKTOP 2 DOOR LEAKING ISSUES
electricmage
Sven
Los Angeles
Bronco 2 door Badlands Sasquatch
Hey Bestop,
Your customer service is so terrible, that I'm going to rely on someone else to chime in here.
I purchased a Trektop/ BD from Bestop and there are gaps under the flap , at the rear window. Any sort of pressure wash, and water leaks in.
Anyone have an potential band aids of fix for this? I know bestop won't respond, because their an absolutely cheap and terrible company.
Also, what sort of awful design are the sliding side panels/windows? Do you guys know how hard it is to slide those in, without the same guides as the rear panel?
Thanks!
BroncocnorB
Paul
Clearwater Beach
1965 Cobra,
You have pics? How long have u had it installed? Mine has been perfect for three years - no leaks whatsoever. Side panels are easy peasy to slide on and off
electricmage
electricmage
Sven
Los Angeles
I can take pics, yes but which top do you have?
BroncocnorB
Paul
Clearwater Beach
1965 Cobra,
I will say this.. the rear quarter metal brackets at the top (top of roll bar)may need to be bent slightly inward to allow the side panels to slide in easier. This I learned a few months into it. I just used a channel lock plier and bent the right rear bracket a milliliter or so inward. No problem on the drivers side. I grease the rubber slide with a little garage door track grease once in a while. I believe the top is VERY SENSITIVE to proper installation. It’s a very tight fit and if you do it right you should have zero problems.
BroncocnorB
Paul
Clearwater Beach
1965 Cobra,
Ford Bronco BESTOP TREKTOP 2 DOOR LEAKING ISSUES IMG_3315
A little masking tape pointer - u might need to bend this top bracket in a little bit that way the side panels align better with groove
electricmage
electricmage
Sven
Los Angeles
Here are my photos. You can see where the gaps are. Total nonsense.
Any sort of upward angle of a sprayer, and I've got water in my Bronco.
I also had no issues with water entering on my 2018 JLU top, aside from from a faulty rear door bar seal (which bestop did eventually replace).
Ford Bronco BESTOP TREKTOP 2 DOOR LEAKING ISSUES PXL_20250730_195306336
Ford Bronco BESTOP TREKTOP 2 DOOR LEAKING ISSUES PXL_20250730_195329372
electricmage
electricmage
Sven
Los Angeles
Yeah, I'll have to do that. Not sure why bestop didn't put those little gliders in, but they are a terrible company, so it's not surprising.
BroncocnorB
Paul
Clearwater Beach
1965 Cobra,
Not sure what you’re doing wrong. Mine looks the same. When the roof flap is down no way water is getting inside unless I purposefully spray water into the gap. :(
Ford Bronco BESTOP TREKTOP 2 DOOR LEAKING ISSUES IMG_3319
Ford Bronco BESTOP TREKTOP 2 DOOR LEAKING ISSUES IMG_3317
electricmage
electricmage
Sven
Los Angeles
I typically have to wash at a DIY car wash, as LA doesn't have a lot of touchless.
Also, your gap appears to be smaller than mine, which isn't helping when I wash it.
What can I say, it happens. Still really bad design.
