Bestop Sunrider Install issue
srd1122
Sarah
NH
2020 Ford Explorer
I purchased the bestop Sunrider for my four-door bronco. I watched the install video and read through the instructions. It appeared to be pretty straightforward and a quick install. On step 2 I ran into an issue where the M6 x 16 bolts were too large for the threaded holes, and I stripped the head trying to force them in. I got the screws removed and ran out to purchase some extras and even the next size down. The next size down were too small, and I ran into the same issue with the new screws. I’m going to reach out bestop tomorrow. Has anyone else run into this issue? Does anyone have any recommendations on how you can slightly widen the threaded holes without ruining the threading? I was so frustrated because I was looking forward to trying it out.
lakesinai
Charleston SC
It's not just fastener diameter, but thread count (20, 24 etc). Then you've got metric vs imperial. Did Besttop send the wrong fasteners, or did this come from a 3rd party?
Swallace
Sean
N. Andover Ma
Toyota ,Gmc and Subaru
I had to keep the two washers when I removed my two door hard top and had to use them as spacers. Not sure if this gives you the clearance on a 4 door
BigBlue7
New Jersey
‘23 Black Diamond Sasquatch
Is this the step where you try to attach the canopy to the bestop frame (before putting it on the bronco)? If so, it's caused by paint overspray on the inside of the nuts. I contacted bestop and they weren't much help, but I just went and bought new bolts with a socket head on them and it allowed me to torque the bolts through the excess paint
Rumbloki
Alton
ATX/PCB
ZR2, 1973 Mach 1
srd1122
Sarah
NH
2020 Ford Explorer
It came from Amazon but Bestop is the seller.
srd1122
Sarah
NH
2020 Ford Explorer
Yes. Do you remember which bolts you got?
BigBlue7
New Jersey
srd1122
Sarah
NH
2020 Ford Explorer
lakesinai
Charleston SC
I'd call Besttop directly. The Skyrider I installed had all the correct fasteners from Besttop. Good luck, that's annoying.
srd1122
Sarah
NH
2020 Ford Explorer
Same size as the ones they provided, just with a different head on in so I could tighten them with socket wrench and not an allen wrench
similar to this https://www.amazon.com/M6-1-0-Hexag...5&keywords=m6+x+16+bolt&qid=1727717454&sr=8-8
Soooo, update. That went great on 2/3 that I installed. The third snapped off inside the hole. I’ve been working diligently to remove the snapped bolt, but even if I can get it out, the thread will probably be ruined. I contacted Bestop to see what my options are. They submitted a warranty claim. Hopefully they’ll be sending me a new top, and if they do, hopefully I don’t run into the same issues.
