Battery trickle charger connections
TBird92651
Tony
Laguna Beach
Ford Bronco
Hi,
I'm about to install a ring connection trickle charger and want to confirm the connection locations. Are these the right places? Thanks.
Ford Bronco Battery trickle charger connections 9AFC5B9D-2B09-4164-A0EC-D603D7603D99_1_201_a
RagnarKon
Ford Bronco, Escape, Focus
There are multiple locations on the Bronco you can connect it to, but yes... the ones you have circled will work.
TBird92651
Tony
Laguna Beach
Ford Bronco
Weird. I hooked it up and the charger is solid red which means it's not connected correctly. Are there better terminals to use?
Lak34ers
Troy
Seattle
Should work. Neg I connect to the tab with the whole in it just below your circle. Is it set to 12 volt AGM. I use a Noco Genius10.
TacosTuesday
Carlsbad, CA
'23 Badlands 2dr 2.7L
i use those terminals for my trickle charger.. make sure your charger is capable of charging an AGM battery. I use a CTEK 12v/4.3A and it works great.
Karl_in_Chicago
Karl
Chicago
Dude, thank you! Wife asked me "did you buy anything during Prime Days?" and I said no, I don't need anything. Your post reminded me I have a CTEK on my Amazon wishlist and I just checked and it's $79.99.
Q - are the stock leads for battery attachment long enough to snake through the grille/front without needing to open the hood? I can always get one of the extensions if need be but don't want to order something I might not need.
Thanks again!
TBird92651
Tony
Laguna Beach
Ford Bronco
I bought the cheapo Motopower charger which I think is only about $13 on PrimeDay. The SAE eyelet connection wire is only about two feet so you will probably need to buy a 4' or 6' wire also.
Karl_in_Chicago
Karl
Chicago
Thanks, that's kind of what I'm expecting with the CTEK as well. Most of their add-ons are for extending the reach of the *charger* from the outlet with less focus on getting the leads from the battery to somewhere useful. They have only one option there and it purports to provide 19", which should be enough, but I'll wait and see.
https://smartercharger.com/collections/accessories/products/ctek-comfort-connect-indicator-eyelet
TacosTuesday
Carlsbad, CA
Thanks again!
they're about 6' long, give or take a foot
