Base Model Bronco Thread
dgorsett
colorado
F250, Mustang, Explorer
Does anyone know how much bigger the tire can be on the factory steel wheels? I actually kinda like the look of the steelies, but the fender gap is pretty extreme. I think 32" is a great fit aesthetically. Just curious how far you can go without replacing the wheels.
255 85 16, Same width as stock base, but 32.6" tall. Available in Cooper Discoverer ST. Will fit stock rims and (probably) allow tire chains. 3.73 gears with the auto might be steep, but the 4.46 with the manual would be sweet.
Ford Bronco Base Model Bronco Thread copvl8-ang-l-jpg-jpg-jpg
Incognito
Phoenix
2017 jk
I keep getting myself all worked up and running through the trims trying to figure out which one is best for me.
I keep coming back to Base 2.7 with Aux.
Can I put 32" tires on the 16" wheels without concern for any re-gearing - even after 150k miles?
***** We put 298k on our f-150 & 245k on the Mustang so I expect at least 200k from the Bronco*****
People put 305/70r16 (33x12r16) and 315/75r16 (35x12.50r16) tires on Wrangler Sport models with the 16x7 steel rims often.
They just use 1.5" wheel spacers and 2 to 2.5" lift to clear the suspension and fenders.
You'll need a local Llantra tire shop to mount the tires. Since they are going on undersized rims.
But you won't flip over and burst into flames in the parking lot, like some seem to imply.
Heck, look at all the undersized tires low riders go with.
Just don't expect full tread life.
ETA: The Base Bronco uses 16x7 steel rims too.
So, same-same, only different.
Incognito
Phoenix
2017 jk
if you get a manual, it comes with 4.46 gears which I think would be ok with 35s
Agreed.
For 35" tires and in direct drive (1 to 1) 4.56 gears are about ideal for an auto, and 4.88 for a stick.
4.46 is less than perfect, factoring in the 2 overdrive gears.
But the 2.3L has the classic equivalent of small block V8 power, so it won't be a problem.
The higher revs and powerband of the 2.3L just means that you use a bit more RPM to get rolling.
Hamhands
America
I reserved a base 4 door. Probably opt for lockers and a hardtop......maybe automatic. I want mine to ride nice and get decent mileage. In stock configuration I think it'll handle the off-roading I intend on doing. BTW anybody have a guess on milage numbers?
DonM
Don
Northern Cincinnati
2021 4DR Base Sasquatch 2.3 in VB
Hamhands....you'll be getting the auto with the Base 4 Door...it's standard. No word on lockers or even other gearing for the Base. Unless you Sasquatch. I'd like the optional 4.27 gearing and rear locker from the Big Bend, along with its rims and tires and grill.
I reserved a Base 4 Door also. Trying to decide on Sasquatch and 2.7 or Big Bend and auto and 4.27 E-locker in the rear!
BigAl
Al
2006 Honda Pilot
Also for comparisons sake the Taco TRD Off Road comes with 16x7's and tons of people put 32s on them. I'm thinking something like 265/75R16
BroncoFanBoy
Brandon
Az
Nissan
4dr base 2.7, hardtop, aux switches... gonna try for 285 75 16 on those 16x7s
Incognito
Phoenix
2017 jk
Yup.
It's starting to look like the 285/75R16 will be the biggest people can go without lifting.
The bugaboo is the Ranger sourced steel rims have a really deep offset.
265/75r16 would be a lot safer.
But this is all just WAGs still we can measure a production model.
kboom180
Kurt
Los Angeles
VW GTI
Bit of a truck newb question. While the stock rims and tires will handle the camping related off-roading I intend to be doing, I do want to buy someones BD steelies and tires when the inevitably hit the market as people upgrade. Mainly for aesthetic reasons. What are some things to consider with an increase in tire size if I plan on going with the 10-speed and 2.3? Things like, speedometer/odometer, gearing, clearance etc.
Broncsquatch
SoCal
66 Mustang
With ~"equal" specs, I think the 4 door Base Model is the best bang for the buck.
Base trim - $34,695
2.7L/10spd -$1900/included
Sasquatch - $5000
Hard Top - $700
Aux switches ~$300(speculating outrageous price)
Mod (Front only) Bumper - $800
Cloth seats, carpet floor, 8” screen.
= Total $43,695 w/ 2.7
Or $41,795 w/ 2.3
**btw, changed 2.7/10 speed AT to $1900. ($3500-standard on Base Model AT $1600)
I feel this is an equivalent BD with a Squatch pkg, 2.7, AT and a Hard Top!
Of course subtract $1,900 if 2.3 is maintained.
Base trim - $40,040 (incl. $1,495 destination)
Gray hard top - $700
2.7L/10spd -$3500
Sasquatch - $4500 (adjusted/survey)
Vinyl seats, washout interior, steel bumpers, bash plates, 8” screen.
= Total $48,740 w/ 2.7
Or $46,840 w/ 2.3
Difference of ~$5,000
(depending on aux switch price)
I also don't NEED (want vs need) the Mid Pack
I can save ~5K now and purchase aftermarket Steel rear bumper, Sliders, lights, etc. at my leisure and when I feel product is financially (overpriced options packages or increased trim level vs a la carte aftermarket) satisfactory.
My .02?
Chrism81
chris
connecticut
Mazda
I'm a bit confused here. So the theoretical price of 2.7 upgrade is how much? I thought I read 1900 for the engine bump and 1600 for automatic switch but this sounds like the 2.7 engine includes automatic. Is that at 1900 or is that 3500?
2.7 does not include an automatic. I believe certain trims come standard w/ auto and some 4 door options. If you are getting the base it will be $3500 for the 2.7.
Blitzinger
New York
Tiguan
and an additional 1600 or 1900 for the automatic?
Mopar2Bronco2021
Houston
2018 Dodge Charger RT 5.7L
If you’re getting the 4 door base, then the 2.7L will be $1900. The auto is standard and is already integrated into the base 4 door price.
Chrism81
chris
connecticut
Mazda
True. I was thinking the 2 door since that's what I reserved. It's kinda annoying Ford has set this up. If you go up to the big bend the 4 door doesn't get the auto. It's like Ford is messing with each trim level so that we can't be completely satisfied.
